My first 350 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2012, 12:46 PM
My first 350 build
Ok so ive decided to build a SBC 350 for nitrous. The goals are a 200-300 shot. For now i guess let me just tackle the bottom end as it will be a while to fund this motor and right now im at phase one, having the block machined, And purchasing a rotating assembly. The block is an "010" 68-76
4-bolt main.
This car will be a track car with very minimal street driving. I dont even have a car as of yet. First i plan to build the motor and then go from there.
I beleive i need to run an all forged rotating assembly correct? I also beleive i want a 10:1 or less compression (Id prefer to run 91). I was told for my power goals of 600+hp i will have to run H beam rods, This correct? Also the machinist guy tells me i should balance the Rotating assembly. Is this a power thing or a reliability thing? I want the motor reliable but i cant afford to do every little trick thing to make maximum power. Anything else i should look for or watch out for is much appreciated.
Also this is my first post so hello everyone. Im not here to suck up your info and scoot. If all goes well some day i can contribute usefull info of my own. Maybe this thread can continue throughout my build from start to finnish.
-Kenny
Old 11-22-2012, 01:10 PM
vinniekq2's Avatar
hello and welcome.First,you are starting at the wrong end of the car.
or better yet,get a car, set up the suspension(or buy a used rolling chasis)driveline and engine need to be matched for racing.
RE: balancing=mandatory and yes it does add a small amount of horse power.
Racing and budget? start with a car,,,,
Old 11-22-2012, 01:22 PM
Well part of the reason im starting with the motor is i live in an apartment with a small single car garage. Im doing this mainly for something to do. The car kind of has to come second as i will likely be building iy in a friends garage and dont want a car with no motor taking up his garage for a long time while i slowly build it.
My budget for the motor is bassically unlimited as ill just throw money at it check by check. but id like to have the motor completed in 9 months or so. Calculate that with my available income and it would ideally be around a $3500 motor. If that price is unrealistic ill just have to extend the build time.
Old 11-22-2012, 01:34 PM
vinniekq2's Avatar
3500 will give you a very nice reliable near stock engine. With out a car how in the world can you figure what parts to put in what engine? something as simple as what generation 350 could mess you up.
Old 11-22-2012, 01:40 PM
techinspector1's Avatar
Wiki Edits: 326
LMAO Vinnie, you are my hero.
Old 11-22-2012, 01:43 PM
Near stock?... I know i can build an all after market cast rotating assembly bottom end for around 1200. Of course i cant use cast parts... but a stock 350 for 3500? The old saying "they saw me coming" would come to mind.
making my own motor mounting points etc in said car is not an issue. Infact i was considering putting the motor in a fox body mustang.
Old 11-22-2012, 01:45 PM
Really looking for info regaurding bottom end component requirements for a reliable nitrous motor.
Old 11-22-2012, 01:55 PM
vinniekq2's Avatar
sorry K,maybe ask CnC what it costs to blue print a block? you need your pistons before you bore the block,therefore you need the heads before you choose the pistons. The block needs to besquared/decked/align honed after it was cleaned,threads chased,new frost plugs and cam bearings.
you will need the crank and rods and pistons to trial fit after boring before decking and squaring
Price out those parts and machine work,add 250-300 for balancing after the second or third trial fitting and measuring piston to valve clearance.
research for parts pricing is your job because your suppliers might be different from the ones I use here?
Old 11-22-2012, 02:04 PM
Right im still not certain on the exact process time line of what i need to do what. as of now my plans are have the block tested and then ask the machinist what parts he needs to move forward.
But again if he needs the entire rotating assembly... all my questions above come into play. If heads are also needed to complete the machining process what stats am i looking for in a head? High cc Low cc? Big exhaust valves? etc.
I dont mean to throw a million questions out.
Old 11-22-2012, 02:19 PM
vinniekq2's Avatar
My question to you,who is going to assemble this engine?
Old 11-22-2012, 02:35 PM
Probably the machinist. Atleast the bottom end. Did i pass all the tests? Can i get my Origonal questions answered now? lol
Old 11-22-2012, 02:38 PM
prostreet6t9's Avatar
Differential/Driveline
You will need a good set of forged pistons. Get yourself a good fuel system and Ignition. If your gonna use a fox body save some money for Diff and suspension up grades.
Old 11-22-2012, 02:44 PM
As far as Crank and Rods do i need to go forged? The machinist said i have to use H beam forged rods. Roger that on fuel, ignition, diff and suspension.
Old 11-22-2012, 03:29 PM
It would be a good idea. Nitrous is pretty hard on stuff.
Old 11-22-2012, 06:03 PM
Alrighty then thats what ill do. Even if it takes 2 years (i hope not) to build this car it will happen. Just a little at a time.
My next project small block 350 chevy smokeb1 Engine 0 01-18-2012 08:53 AM
350 build questions, looking for 300-350 hp Jaiden2010 Engine 18 06-23-2011 07:49 AM
350 Build Up Please Look Over SBC-S-15 Engine 14 07-11-2004 06:52 AM
350 build Captnscotty Engine 15 09-11-2003 09:04 PM
