My first hot rod project.Lot's of questions - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-14-2013, 06:45 PM
Last journal entry: 41 chevy frame on the move.
worked on rotisserie today
It's been a while coming.I have to get more steel at logans steel yard.Then a trip to "Tractor Supply" for some caster wheels.Plan is to get the frame bolted onto rotisserie this week.Here's what I have so far.
stefanP
Name:	41 chevyhotrod scotts58th birthday 012.JPG
  #32 (permalink)
Old 04-18-2013, 08:15 PM
4 wivel casters welded in place!!
Here you go.Now one more peice of 2 1/2 square tubing.Then we should be ready tohang the frame
Name:	rotsieerie with wheels 001.JPG
ID:	73304   Click image for larger version
Name:	rotsieerie with wheels 002.JPG
  #33 (permalink)
Old 04-18-2013, 09:46 PM
Proud LOSER
Originally Posted by stefanP View Post
thanxs, techinspector1.Maybe I'll save the$$$ and go for a th350 or th400.My left leg isn't that great so I really don't want to go standard.Plus "HEMI 4spd's" are getting harder to find .
stefanP
Listen to tech on the trans advise, the OD is heaven, especially for a street rod that's going to see lots of use. And everyone jumps to the 700 but the overlooked TH200 4R is stronger out of the box, and has a far nicer gear spread. The only real drawback is the 27 spline input shaft which makes converter selection a little more difficult and sometimes tricky. You will see 200/700 converters available but don't get confused and think that any 700r4 converter will work, its only pre 87 I believe that share the same 27 spline, later 700's went to 30.
  #34 (permalink)
Old 04-21-2013, 11:26 AM
Thanxs for the tranny advise.I'll put this on my "HIT LIST" of parts.Back to work.................
  #35 (permalink)
Old 04-28-2013, 06:22 PM
Well the rotisserie is apart and painted.Man what a job.Hopefully I can get it back togther and back on the frame.Then I start to take the chassi apart and get cleaning and prep for NEW PARTS!!!!!.STAY TUNED!!!!!!!!!!!!!
stefanP
  #36 (permalink)
Old 05-02-2013, 06:58 AM
Well the frame is on the rotisserie .Now the question What should I do to the frame?Sand blast or wire brush?on a grinder?
  #37 (permalink)
Old 05-02-2013, 08:19 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Sandblast.
  #38 (permalink)
Old 05-02-2013, 11:27 AM
Hi stefan, I've owned my '41 chevy for 46 years. peice by peice it has been a work in progress. In 1969 i put a '57 chevy rear end in it, its still under there! Today i'm swithching transmissions. I broke the last 200r4! no fault of the trans. you will most likely cut out the old trans xmember, the forward gusets that go to the frame will be PACKED FULL of dirt and gravel!! or, most are. so check out the frame also and clean it out some how. have fun!
  #39 (permalink)
Old 05-05-2013, 01:48 AM
Crossmember removal?
Can someone tell me if this crossmember will need to be removed,in converting to a modern drivetrain?
Name:	Easthaddam old engine  and car show 039.JPG
  #40 (permalink)
Old 05-05-2013, 04:58 AM
I used it with the 3 speed and 400 turbo and original master cyl. but with the speed way master cyl. and 200 4r it all had to go!!
  #41 (permalink)
Old 05-06-2013, 05:04 PM
Crossmember is "GONE"!!! Waiting to pick up car trailer to bring frame to the drystripper.Stay tuned........................
  #42 (permalink)
Old 05-19-2013, 06:41 PM
Well, A week later and the frame is back from the dry stripper(New England Dry Stripping).$280.oo bucks and the frame looks nice.I then sprayed the frame with epoxy primer from eastwood company.This is just to protect it from the elements.I have to do some welding.So when all is completed I will be painting the frame black.Also put in a order for my CE front suspension crossmember,motor mounts,trannny mount and radiator mount.Hopefull this weekend I will start to assmbly process.I'll update the thread with pictures of the frame.To and from the dry stripper.
stefanP
  #43 (permalink)
Old 05-26-2013, 07:20 AM
Well, If the "SIBERIAN WEATHER" lets up I can move forward on the frame.28th is the delivery date for my suspension & frame parts .I also received on Friday my inner frame coating kit from eastwood.Welding will commence on Monday.More updates to follow.STAY WARM!!!
stefanP
  #44 (permalink)
Old 05-27-2013, 06:12 AM
deadbodyman's Avatar
Wiki Edits: 11
Just a word of caution dont spray the epoxy unless its at least 65degrees it wont stick to the metal very well and it'll give you problems later on...
sounds like your well on your way I love doing this part ,itsa lotta fun ...
  #45 (permalink)
Old 05-27-2013, 10:30 AM
camero donor rear end
Well,Craig's list hooked me up with a 70's/80's rear end($275). Looks to be a 3.73 posi:thumbup. Another part to the puzzle.Just think I was hoping to be in a "Rolling Chassi" by october
Name:	41 chevy driveline parts and camero rear end 002.JPG
ID:	74337   Click image for larger version
Name:	41 chevy driveline parts and camero rear end 003.JPG
Hot Rod Design Cali-art Hot Rod Art 5 09-17-2010 04:53 PM
My First Hot Rod!... project TexasTechX1 Hotrodding Basics 46 04-21-2009 07:40 AM
hot rod Fabrication Denton Md frdsuperduty Introduce Yourself 4 04-14-2008 08:11 AM
HOT ROD vs Car Craft magazine FASTCHEVY Hotrodders' Lounge 35 03-25-2008 04:11 PM
My Hot Rod, is now a SHOT ROD! bullheimer Hotrodders' Lounge 3 04-15-2004 10:25 AM
