My first hot rod project.Lot's of questions - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 07-13-2013, 05:31 PM
Please do not use Painless .I put bigger speaker wires in than they use for the tail lamps. Hay Wire E-series
The Following User Says Thank You to 46streetrod For This Useful Post:
stefanP (07-14-2013)
  #62 (permalink)
Old 07-14-2013, 07:17 AM
Last journal entry: 41 chevy frame on the move.
Well,all the front end components are bolted in place.Now I have to prime and paint the "A" arms and any related parts that will not receive paint once bolted in place.Also need to decide on what chassi paint will be used.My local napa deals sells the Bill Hirshire chassi black .Also have been looking at Eastwood paints.Stay tuned and stay koooooooooool.90 + HUMIDITY all next week here in Connecticut.
stefanP
  #63 (permalink)
Old 07-21-2013, 07:13 AM
front end complete(so far)
PLEASE READ ALL PAPER WORK WITH YOUR NU PARTS Well everything is on the front end as far as I can go. You needto purchase or make your own struts in place of the springs IF your building your car from frame up.CE say NOT TO INSTALE SPRINGS UNTIL CAR IS COMPLETE!!!. So next for me is to get the rear spring mounts and shackels installed.Then we paints the whole thing!!!!!!!!!!:coo l: stay toon.........
stefanP
Name:	41chevy part2 003.JPG
ID:	75858   Click image for larger version
Name:	41chevy part2 004.JPG
  #64 (permalink)
Old 07-05-2014, 04:22 PM
Slite updates.
OH Ya almost one year but not much to show I have the chassi outside through the weather and the front spindels got rusty.So I just cleaned them up and put on a rubber protective coating.I purchased the stuff at harbor freight tools.Suppose to be a tool coating.Anyway I see if this protects the spindels.Anyway I purchased most of my Street Rod Head Quarters.But all the rubber components like ball joint rubber covers and the leaf spring rubbers are all cracking badly.No I'm not happy.Has anyone else experienced this?? I'm taking pictures and sending them back to SRH to see what they say.The frame has only been through one newengland winter on t he rottiserrie!! I can't imagine what will happen whe I start to drive the car!!
stefanP
  #65 (permalink)
Old 07-06-2014, 07:35 PM
1971BB427's Avatar
Well those parts weren't designed to sit out in the weather year around. Everything that is sitting out should be covered, painted, and greased where necessary. Why not get some cheap plastic tarps and wrap the project up over the winter, and duct tape it on to hold it? All the bare metal that got the rubber coating will more than likely be a real pain to remove later, and if all the rust wasn't cleaned off, it will rust from underneath the rubber coating.
  #66 (permalink)
Old 07-25-2014, 12:44 PM
Well we are moving forward.Brake master/booster and peddle assembly arrived.Now mocking up position for proportioning valve.Pictures to come.
  #67 (permalink)
Old 08-02-2014, 05:55 PM
brake lines instaled!!!
Well we are moving forward.Waiting for the Lokar hand brake cables and we will be finished.Here are pictures I promised.Using the copper /alloy brake line.SWEEEEEEEEEEET Stuff to work with.
Name:	prohillclimb 41 chevy brakes 113.JPG
ID:	164714   Click image for larger version
Name:	prohillclimb 41 chevy brakes 115.JPG
ID:	164722   Click image for larger version
Name:	prohillclimb 41 chevy brakes 116.JPG
ID:	164730   Click image for larger version
Name:	prohillclimb 41 chevy brakes 114.JPG
  #68 (permalink)
Old 08-03-2014, 05:36 AM
Today I will pick up a 200r4 automatic transmission for this car. I'd like to get the engine/trans mocked up next.STAY TUNED!!!
  #69 (permalink)
Old 08-03-2014, 07:22 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Right on.
She's coming along nicely. Looking forward to more pics/progress.
  #70 (permalink)
Old 08-03-2014, 05:29 PM
Transmision and "mock up" drive shaft have been purchased.Spent time at the car wash power washing and degreessing transmission.Will post pictures when taken with digital camera.Looking at Saturday to mock up trans/engine in chassi.Hold on!!
  #71 (permalink)
Old 08-03-2014, 06:36 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
T.Spent time at the car wash power washing and degreessing transmission.
Not good.
I'm all for moving forward, but polluting your own home is not a great idea.
  #72 (permalink)
Old 08-03-2014, 07:05 PM
I figure the drain at the car wash has a filter system or something.Most of the greasy stuff was lite grime.If this offends you,I will keep it to my self.
  #73 (permalink)
Old 08-04-2014, 04:55 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Doesn't offend me at all.
Just throwing it out there. All sewage usually ends up back where your drinking water comes from is all. It's in your own backyard, not mine.
Just something to consider.
  #74 (permalink)
Old 08-04-2014, 08:49 AM
Ana Ana is offline
It is definitely a project!
I recently got myself a 1973 Ford Capri MK1.
It's completely rusty, no brakes, the engine's ridiculous.
I'll need a lot of patience, and a lot of money to get the work done.
Good luck to you!
The Following User Says Thank You to Ana For This Useful Post:
AutoGear (08-05-2014)
  #75 (permalink)
Old 09-13-2014, 02:31 PM
Sorry to be quiet.A little breaK in the action.Tommorro I will be making adapter plates to mount my body on the rotisserier.Then onto the body work!! What I did do in the past couple weeks was to put the body onto the frame and check to see all items are lining up.This included putting in engine and transmission.Had to modify tranny cross memberAll looks good to go. Stay tuned!
Hot Rod Design Cali-art Hot Rod Art 5 09-17-2010 04:53 PM
My First Hot Rod!... project TexasTechX1 Hotrodding Basics 46 04-21-2009 07:40 AM
hot rod Fabrication Denton Md frdsuperduty Introduce Yourself 4 04-14-2008 08:11 AM
HOT ROD vs Car Craft magazine FASTCHEVY Hotrodders' Lounge 35 03-25-2008 04:11 PM
My Hot Rod, is now a SHOT ROD! bullheimer Hotrodders' Lounge 3 04-15-2004 10:25 AM
