My First "Mini - Project" ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2010, 05:31 PM
Here it is - did it on my Singer 111W153 and learned it all right here through Dan's tutorials. Plenty went wrong - and I'm glad it did! I learned a lot and the next one should be much better.
I did notice thought that my machine works much better with a good size piece of work under it than somnething thin.
Old 02-13-2010, 10:48 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Remember that these machines were intended to sew heavy stuff, not light stuff, so avoid trying to sew anything too light weight, because the machine will fail miserably unless you install a much finer needle and make some adjustments to the machine.
Old 02-14-2010, 11:47 AM
I think the smallest needle the machine will accept is a 14. The highest is a 24
Old 02-15-2010, 08:39 AM
cboy's Avatar
Last journal entry: Finished
The mini project looks pretty good Coodeville
Always learning...and sharing what I've learned.
Old 02-15-2010, 12:23 PM
Thank you very much. I'm going to do a second one later today. I'll attempt to correct as many mistakes as I can.
"You must crawl before you can walk. And if you don't want to crawl - your screwed."
Old 02-15-2010, 12:33 PM
Dirk Zixxer
I know squat about sewing machines. Is there a difference between the one you mentioned and the kind you get at Sears? If so where do you get those models?
Old 02-15-2010, 05:02 PM
There's a ton of difference. The machine at Sears is designed for home use and materials such as dress's and other garments. Plus, the Sear's machines don;t have a compound feed walking foot. That's the biggest difference of all.
I looked in Sears and really found nothing worth while. As Dan said in a previous post, " any machine can sew two pieces of leather together. But try doing it with on half inch sew foam." The walking foot and compound feed wins on this one since the needle helps to pull the material.
Flathead V8 ?'s " for school project" 51FordDuff General Rodding Tech 4 06-12-2009 02:55 PM
