My first Spread..... Of filler that is.. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-01-2006, 09:36 PM
Good point crash. I am having a hard time seeing where this is. If that is a seam that is not welded solid, could be a problem putting body filler over it if any water gets behind the filler.
  #17 (permalink)
Old 01-01-2006, 09:55 PM
That's the one.
Crash, Good eyes. That's the very one. Thats where the uniside pieces fits right in there. So I used a MIG welder with .025 wire and 75/25 gas mixture and re- did all the spot welds. Once I got it tight I then grinded them down flush and shot the weld line with two coats of ppg 2K mp170 epoxy primer and then started my fill process. I was going to leave the weld line sunken but I wanted to see what It would look like flush and thus the flush filler line. I know ford did not make it that way but I like the flush look. so I'm giving it a try. Ken I went ahead and put down a 2 layers of epoxy primer to help prevent moisture seeping through. Well tommorrow's another day.
  #18 (permalink)
Old 01-02-2006, 11:24 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
Well, the thing is, if you put filler over a seam that's only plug welded and not welded solid, it will probably crack later. I've done many repairs similar to this, and have always left at least an 1/8 inch gap down to the metal right where the panels overlap. That gap gets filled with seam sealer, which will stay flexible and prevent the filler from cracking. I hope I'm not raining on your parade!
body filler esahlin Body - Exterior 18 02-12-2006 03:59 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 01:22 AM
body line cole5_0 Body - Exterior 13 10-14-2005 04:57 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 05:30 PM
Body Filler do's & don'ts Ron M Body - Exterior 2 09-07-2004 06:00 AM
