My Flywheel, can i polish it up to make it better? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2003, 03:01 PM
Rubberman2003's Avatar
Post My Flywheel, can i polish it up to make it better?
Would it help to run something like emry cloth over it to clean it up real good, i dunno if this would help anything at all...prolly a dumb Q
Old 02-05-2003, 03:04 PM
5.0Towncar's Avatar
Post
Is your trans a manual? If it is I think if it is smooth and had the residue from the emry cloth on it then your clutch could slip a bit. But remember I am mentally retarted Steve
Old 02-05-2003, 03:05 PM
Frisco's Avatar
Glad To Be Here
Post
If the flywheel is for a standard shift trans and is not a flex plate it can be cleaned up the way you asked about. If it has slight heat cracks and/or is not flat, it should be resurfaced. If it is badly discolored (Blue) from heat or the heat cracks are deep, it is best to replace it.
Old 02-05-2003, 03:26 PM
5.0Towncar's Avatar
Post
Told you I was a dumb@$$. Steve
Old 02-05-2003, 03:48 PM
Post
Sorry the turbo 350 is a automatic
Old 02-06-2003, 12:53 AM
Frisco's Avatar
Glad To Be Here
Post
[quote]Originally posted by Rubberman2003:
<strong>Sorry the turbo 350 is a automatic</strong><hr></blockquote>
Since this is the case; just clean the flex plate up with a wire brush.
