Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is My Gearbox Worn? - Pictures Included
Old 01-06-2013, 06:58 AM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
The main shaft is worn where it runs in the bearing. There are places here where you can send the shaft and have it welded and re-ground. You may have some place like that where you are. Check inside the input gear to see if it is also worn. Chances are that if the shaft is worn the inside of the input gear will be worn too.
