The main shaft is worn where it runs in the bearing. There are places here where you can send the shaft and have it welded and re-ground. You may have some place like that where you are. Check inside the input gear to see if it is also worn. Chances are that if the shaft is worn the inside of the input gear will be worn too.
Thanks
The input shaft looks ok from what I can tell It runs on caged needle bearings if that makes any difference Is there any type of hardening that could/should be done to the mainshaft tip, or is it just a case of grinding and renewing? |
It needs to be welded with a hard surfacing rod and then ground to the correct size. T5 transmissions are very popular here in the USA and they have a bad reputation for doing the same thing. There are several places here that recondition the shaft for the T5 and other transmission. Check with transmission shops around you and see if they know of anyone who can do this kind of work on your shaft.
Excellent, thanks!
Just to confirm (as I'm still very much learning) I need to ask if they can "weld the mainshaft tip with a hard surfacing rod, and then regrind to original sizing" Also, the tip is 12mm in diameter Later gearboxes had an 18mm tip, but still have the same wear issues Could I do something here to resize mine to 18mm, or would that make no/little difference? Thanks again for your help |
If you increase the size of the shaft would the larger bearing fit inside the input gear? Your shaft could be welded up to the larger diameter and ground, but would you have to replace the input gear to make it work? The more heat that is put into the shaft from welding, the greater the chance of ruining the shaft.
There are several ways to seld the shaft. TIG welding is comon, but spray welding is getting more popular for shaft build up. |
Mainshaft needs to be fixed or replaced.
Check the bore of your input. If it looks the same, you will need to replace it. Blocker rings need replaced. Polish the sharp edges of the nick on 1st. As little as you use it, you won't notice any noise and the chip is not bad enough to worry about. The 1st/2nd/Reverse slider should be replaced, but if you are careful shifting into reverse it could last a long time the way it is. The 3rd/4th syncro is not bad enough to worry about. |
Thanks again guys, it's all very much appreciated!
Some more pictures for you...... First picture shows Layshaft cluster ![]() Here, you can make out the contact patch on the first gear There is also a chip on the gear I have highlighted, and also the gear two steps nearer to the camera ![]() Wear patch on second gear ![]() Chips on second gear ![]() Couple of chips on third gear ![]() Front of layshaft There's a small line where the needle rollers locate, but it doesn't seem to be worn into the surface ![]() Rear of layshaft
| Pictures from the past. Vintage Indy and Bonnivile pictures | boothboy | Hotrodders' Lounge | 7 | 07-28-2012 08:50 PM |
| Wanted to say THANK YOU, pics included. | Why J? | Body - Exterior | 14 | 07-24-2009 06:38 AM |
| Just signed up-project pictures included. | A_Roldan | Introduce Yourself | 10 | 09-13-2008 01:21 PM |
| Is Knowledge Base included in a Search? | cboy | Hotrodders Site Suggestions and Help | 2 | 01-07-2005 05:23 PM |
| Using lead for body damage (Pictures Included) | Project87c10 | Body - Exterior | 2 | 10-21-2004 09:40 AM |
