my headlights dont work - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2009, 05:03 PM
all of a sudden they stopped working. i checked the fuses they seem fine. i checked the bulbs and they seem fine. i checked the highbeam switch and connector and put new connector on because they seemed corroded but they still dont work. all the other lights work-dash, tail lights, brake lights, and the yellow ones in the front. just the headlights dont. not even the highbeams work. btw if it matters i drive an 81 camaro
Old 07-29-2009, 05:47 PM
ericnova72's Avatar
More for Less Racer
The power feed wire at the headlight switch is divided into two wires where it plugs onto the switch, one side for headlights and one side for all the rest. Maybe the switch has gone bad, or maybe you have burnt a fusible link wire. You will have to get a test light and start probing for power in and out of the headlight switch.
Old 08-01-2009, 10:49 AM
i just checked the connector on the back of the headlight and its all melted on what seems to be the ground prong. it was still connected but the casing was melted. what would cause this? and why would make both headlights go out?
Old 08-01-2009, 11:32 AM
302 Z28's Avatar
Corroded connectors cause excessive resistance. Excessive resistance causes heat which melts the connector housings. You need to check every part of the headlamp system and clean or replace as need be all the connections. You may even have some melted wiring that needs to be replaced.
Vince
Old 08-01-2009, 11:41 AM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
buggmann
i had a 85 that did that the head light switch
was bad and it made the wires melt like that
the main power wire that went in to the switch
was bad and took the rest out take a look at the
head light switch and the plug and go from their
Old 08-01-2009, 12:08 PM
Headlights
If you have to replace the lights I suggest you look at this site and see if you want to go this way. I just got mine yesterday.
www.xenonlink.com they are play and go HID lights. What a difference in the 2 buld's. It is almost like day time when you switch them on and they use a lot less power than the standard Halo's.
Old 08-01-2009, 12:51 PM
i replaced the headlight switch and the headlight connectors and they still dont work. they had 2 wires going into each prong and the replacement only had one wire for each prong so i just split the wire and attached each wire to half the wire i guess u would say but that seemed like it should work but still no headlights. where should i go from here?
Old 08-01-2009, 08:23 PM
Have you tried a voltage meter to see if you have proper power to the headlight plugs?
Old 08-02-2009, 11:55 AM
no i havent. thank you ill check that today
Old 08-03-2009, 09:47 AM
does anyone know where the fuse for the headlights might be? i checked all the fuses but someone told me sometimes you cant really see the break
Old 08-03-2009, 10:07 AM
<a href="http://rides.webshots.com/photo/2133608390068017067jYiNFM"><img src="http://thumb7.webshots.net/t/62/162/6/8/39/2133608390068017067jYiNFM_th.jpg" alt="fuse box"></a>
which one is the headlight fuse?
Old 08-03-2009, 01:51 PM
Joe G's Avatar
Headlights do not have a fuse. They have an auto-reset circuit breaker built into the headlight switch.
Old 08-04-2009, 11:30 AM
o. well i replaced the switch the headlight connectors, checked the wires and the all seem fine i took out the fuse box as much as i could and looked around it. and i can find any burnt wires. does anyone have any suggestions?
Old 08-04-2009, 12:07 PM
302 Z28's Avatar
Do you have access to a volt/ohm meter and know how to use it? If so you need to confirm you have 12 volts at your headlamp switch.
Vince
Old 08-04-2009, 03:51 PM
i got a multiuse tester at autozone and put it on volts and i got between 8.68 and 12.3 volts from the power wire going to the switch. but then i tested the switch by running a wire from the power to the prong it goes on the touching the tester to an outgoing wire and got .03 i think. i dont know exactly how tht all works though. im not positive how to test all that but the switch is new
central valley engine work Echofive Engine 1 10-06-2004 02:22 AM
Stuff I work on at work :) esears Hotrodders' Lounge 6 09-29-2003 02:08 PM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 02:59 PM
camaro headlights chevcamz28newbie Electrical 4 08-17-2003 04:43 PM
83 olds Cutlass No Headlights Dans83Olds Electrical 9 08-16-2003 06:49 PM
