Which of my heads to use on this SBC 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2013, 11:50 AM
Ok so im new to this site and somewhat new to modifying so I need some advice I have a c10 with a 350 4 bolt mane edelbrock preformer pluss cam action plus intake msd street fire distributor holly 600 and long tubes and im thinking about doing the heads I was wondering what would b best choice I have 920 castings now with dished pistons my other options are 416 305s or swirl port 193 castings money is tight and I cant afford vortecs porting will b done I just want something that will fry my tires n do good in a 1/8 mile mpg not a problem as its not a dd thanks in advance
Old 02-23-2013, 12:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mbwilson,
Welcome to Hotrodders
I edited the thread title. Please do not "help" as a thread title, place some information in the title so the members have an idea of your problem
Old 02-23-2013, 05:17 PM
I don't "know" the 920 casting. Anyone? Is it similar to a more common number?
The 305 heads have a small chamber. If you have "dished" pistons, that won't present a problem. The intake valve is a bit small and should be upgraded to the 1.94. Unshrouding the intake valve in the chamber helps a bit.
The 193s are GREAT for torque and low-end power. They're pretty much "done" after 4,000-4,500 RPM. I wouldn't think those suited to your "package" ("Action Plus"???) Is that an Edelbrock marketing scheme? I don't really keep track. The heads they recommend are probably the best ones to use with that package. I doubt they'll recommend a non-Edelrock head...
You say "C-10". Does that mean this is an older truck? So center-bolt covers aren't necessary? There's a RAFT of factory heads around that preform pretty well.
Tell us more... About the application, I mean.
Jim
Old 02-23-2013, 06:09 PM
vinniekq2's Avatar
welcome to the forum. what is your budget for heads and head work?
Old 02-23-2013, 07:28 PM
The truck is a 1973 so the valve covers are paremiter bolt patternall I really know is that the 920s are from what I understand like 882s 76cc chamber and the intake is made by wiland and as far as a budget someone gave me the swirl port heads and I have a line on the 416s rebuilt for 150 and that leaves me with about 250 to 300 for porting if at all possible hope this info helps
305 heads or 350 heads on sbc 355 ryan v Engine 5 09-20-2012 11:21 AM
Which Heads For SBC 350? MonteCarlo80 Engine 18 03-27-2012 04:53 PM
sbc 350 heads turbofirebird350 Engine 4 11-22-2010 10:30 PM
New or Old? 350 sbc heads RexKarr Engine 23 03-24-2009 11:52 PM
SBC 350 Heads SBC-S-15 Engine 4 06-02-2004 12:59 AM
