My Holley is corroding inside? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2009, 10:28 PM
DENCOUCH's Avatar
Whoa! I have a Holley street avenger carb that appears to have a finish that is flaking off inside the float bowls. Under the metering block gaskets it appears that bubbles of corrosion have formed that have to be scraped off with a putty knife. Is it the fuel that I am using that is causing this to happen? I have to remove the carb again because I have now discovered that the accelerator pump nozzle is only dripping instead of squirting. GRRRR!
Old 08-13-2009, 10:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'd be GRRRR! too!!!
If it's new, take it back. The squirters are likely plugged w/the corrosion you mentioned. And it isn't likely to stop, either. Once the plating is off of the zinc, the metal is very reactive.
Old 08-13-2009, 10:41 PM
What type of fuel are you using?
Old 08-13-2009, 10:45 PM
DENCOUCH's Avatar
I am using premium pump gas, Arco brand.
Old 08-14-2009, 09:19 AM
SSedan64's Avatar
I read a thread a few days ago, someone had the same problem. Flaking inside the carb. The poster called Holley about getting them to send him a replacement part. Believe it or not Holley said they would feel more comfortable just sending him a Brand New Carb!! I can't remember where I saw the thread and got tired of looking for it. I say give Holley a call.
Old 08-14-2009, 04:43 PM
DENCOUCH's Avatar
Thanks pal! I am so glad that Ifound this site!
Old 08-14-2009, 05:04 PM
Water in the fuel, and probably more than the 10% ethanol they're supposed to have.
I have noticed that when I get ARCO in Everett, my engine is less ping prone than when using Chevron, Union, or Shell. I don't think that's better octane or a more temp resistant formula of organics in ARCO, I think it's water or excess alcohol, so I don't use that stuff unless it's the only choice to get home in the middle of the night.
Bogie
Old 08-15-2009, 09:13 PM
DENCOUCH's Avatar
I contacted Holley...
I contacted Holley and explained my problem to them. It seems that they received a bad batch of castings from the foundry at one time.
They emailed me a contact number so that I may talk to them Monday.
I hope they are willing to help me out on this. Many of the months I owned this carb, the car was idle in the driveway as the tires aren't worth a nickle in the snow & ice.
I will keep you fellas posted as more information is available.
Old 08-17-2009, 05:38 PM
DENCOUCH's Avatar
Happy ending
I spoke with "Woody" from Holley today. He asked for the series of numbers that are stamped on the choke air horn in order to identify the carb I had. After I spoke, he verified that the numbers I gave him put me smack dab in the series of the bad batch!
Nice guy, he told me to mail it back to them and he would send me a new one from a better batch!
I love it when a company stands behind their product!
Don't you!
Holley (ProForm) Carb Problem leejoy Engine 30 04-01-2011 11:36 AM
Problem: Buick 231 V6 w/390 cfm Holley chevypanel46 Engine 7 08-30-2008 10:02 AM
Help Needed Adjusting Holley DP Mustangsaly Engine 16 07-11-2008 12:17 PM
More Holley to Q-jet MPG results 454C10 Engine 15 10-09-2007 09:56 AM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 09:55 PM
