Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - my home built paint booth!
Old 05-14-2011, 10:17 AM
xpsyclonex2002 xpsyclonex2002 is offline
Originally Posted by deadbodyman
Cool... lets see some vids of you painting and some pics of the car when your done...
try tar paper on the floor with duct tape on the seams ,saves a lot of time ...Then duct tape the plastic on the walls to the tar papered floor
If you watch the video, youtube has the other videos I made of me spraying the car, and all of the problems I had. My spray gun was "pulsing" when I sprayed my first base coat and caused me a ton of problems. I eventually found that the fluid tip seal had fell out of the gun the last time I cleaned it and was causing the problem. I put in a new seal and it works fine now. The biggest thing I found out though is that my body work looks great. All that block sanding really paid off. Today I spray the rest of the base coats on.
