My intake and carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2008, 07:07 AM
71haulnazz's Avatar
My intake and carb?
I have an edelbrock street master intake and holley 650 carb. They have been sitting for a while. What would be the best way to get the intake clean. It looks as it hadf a nice shine at one time it is pretty bad looking now though. And as for the carb should i just soak in carb clener and then rebuild. I was thinking of having the intake glass bead blasted but i really cant find anyone in the are who will do it for anything close to reasonable.
Old 09-16-2008, 09:45 AM
kleen56's Avatar
Unfortunately, nothing is cheap anymore. Glass beading is the way to go in cleaning up an intake. If it's been polished before, you might just need a metal polishing compound and do it yourself. As for the carb, it might still be OK to use. I would check if any dirt or anything got in the carb while sitting. Blow some gentle air into the carb to remove dust, etc. If it doesn't run, you can always take it apart at that time.
Old 09-16-2008, 09:55 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Yep, glass beading with low air pressure. I built a 302 Ford several years ago and used the Streetmaster on it. It wouldn't make much power in the upper rpm range, but low end and mid-range was excellent. Throttle response was fantastic.
Old 09-16-2008, 10:27 AM
71haulnazz's Avatar
It is the older intake and can I glass bead it myself??????
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
SBC 283 intake & Carb Swap Problems iceman_77 Engine 4 02-13-2007 05:49 PM
Intake Manifold and Carb Ozz1967 Engine 9 12-29-2005 12:34 PM
Performer RPM intake & carb Q MegaTherion Hotrodding Basics 1 09-14-2005 04:13 PM
Stipud ? Maybe/Need help determining my Carb and intake ArchonRacing Hotrodding Basics 8 01-15-2005 06:03 PM
