Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My money pit 88 Camaro
Old 03-20-2011, 09:26 AM
killerformula's Avatar
killerformula killerformula is offline
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
I think the v6 cars usually had a pretty steep rear gear, do you know what the current gears are? Is this a 700R or a manual?
I tend to think gearing isn't your issue, either trans will give you a good multiplier. What are the specs on this 355? Are you sure you're running enough timing?
K
