my moter coughts back throw the carb at low rpm - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2004, 04:53 AM
302truck's Avatar
New Member
i have a 302 that has jist been rebilt it hast roush 200 winser lite heades and a comp .520 intack 523 exaust.with roller rockers.edelbrock intake and holly 6oo singole feed carbat low end it is reil sluges untile about 2000 then it rilly comes alive i have it in a 1976 ford f150 4x4 with a three speed over drive and in forthe gear at 60 ites rilly low rpm . and some times it coughts back throw the carb can iny one tell me how to fix it and why ites doing it
Old 01-06-2004, 07:48 AM
Technical Support Barry Grant
Normally a backfire through the carburetor is an indication of being too lean. This may also be why your acceleration is sluggish.
Assuming you have your idle, and floats set properly we'd recommend going larger on the squirter nozzle size.
Old 01-06-2004, 07:54 AM
Frisco's Avatar
Glad To Be Here
Timing is too retarded.
Old 01-06-2004, 10:15 AM
302truck's Avatar
New Member
thank you for the addvice. i ask the comp cam teckes and they told me to set the timeing at 12 to 14 but it woldint even run at that so the book seed 10 so thates what i got it at.i tried the idole mix up and down but still the same. every thing is brande new so ites go me stumped
Old 01-06-2004, 10:49 AM
Frisco's Avatar
Glad To Be Here
What problems did you have when you increased the initial timing?
Did you have the vacuum advance hose disconnected from the cannister and plugged when you set the timing?
Are you running the vacuum advance hose to the 'Full' or 'Ported' connection? Try both and see which works best for you. I prefer the 'Full' port connection.
