my mud truck back firing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2009, 12:46 PM
my mud trucks back fireing though the carb,no fire mostly air.i cant get it to turn over getting gas though new bench tested carb timing set up the guy i got it from had it different fired then i change to spec now nothing help
Old 08-09-2009, 02:23 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What's a "new bench tested carb timing setup"?
Kidding aside, you need to break up your sentences to make it easier for other people to read. You're not going to get much help if people can't understand what you are saying.
Old 08-09-2009, 07:51 PM
poncho62's Avatar
Wiki Edits: 5
Broken rocker, bent pushrod.........
Old 08-09-2009, 08:37 PM
The mobile view is crap
jibber jabber jibber jabber. what is your question. I am so confused by reading your post I almost passed out.
Old 08-09-2009, 08:40 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Make sure the accelerator pump is squirting gas. If it don't, it can cause a backfire.
finally getting back to work on my old truck pancake Introduce Yourself 1 04-10-2009 05:59 AM
back firing delsman Engine 3 06-17-2006 12:16 PM
to short to shake mud truck Greg Malone Introduce Yourself 1 03-02-2006 11:16 AM
back firing poundst Engine 5 05-01-2004 09:24 AM
