My New Air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2006, 04:20 PM
montea's Avatar
tryn to learn
just picked up a Eagle 60 gallon single stage that puts out 18.5cfm@100, i been using a 20gallon that puts out 5.5cfm@90 so the new one should be nice. i wish i had some help getting it off the back of my truck, its a heavy sucker. my shop crane didn't go high enough to get it off so i had alot of heavy work. hmmm now where to put it
What kind of sealant is used for the pressure gauge? can i just use Teflon tape? i had to remove it so i could wrap a chain under the top mounting plate to move the compressor in the garage with the crane.
Old 12-14-2006, 04:31 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Teflon tape should be fine. I believe (not 110% sure so don't take this as gospel truth) that all they used in the factory was Teflon tape. That's all mine had. And that's what I used to seal the hose to the regulator too. No problems so far.
In a while, Chet.
Old 12-14-2006, 05:13 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Oh yeah! That is the last compressor you will buy I bet. Very nice. I like Teflon tape better than anything else I have tried for air lines. Pipe joint compound goo always starts leaking when I have used that.
Old 12-14-2006, 06:36 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The teflon tape is fine....just be careful that you place it so none will get over the end of the fiting. Great looking compressor.....boy Santa was good to you!
Old 12-14-2006, 07:00 PM
Definately teflon tape, I've Used a few different compounds and i can easily say tape is the way to go, no mess and if you ever change your line setup it releases easily. My new shop had existing lines running everywhere, when i changed them to a non polish setup (no offense guys) three of the nipples broke from some grey compound they used, so I'm sticking to tape from now on.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Crappy Air Compressor Wont work rbfpezcore Garage - Tools 7 06-12-2005 02:24 PM
Adding 2nd air tank to compressor cboy Garage - Tools 7 10-26-2004 10:17 PM
Anyone Looking For An Air Compressor ?????? STATUTORY GRAPE Body - Exterior 2 07-14-2003 06:24 PM
