Yes, my crossmember. Need to pull the engine to remove the pan.
How sweet it is. No oil or coolant leaks, and proceeded to gain some more experience for my 3rd drive in the Track-T. Headed off to a girlfriend's home who lives at the edge of the valley downhill from me on 2 lane, smooth mountain roads, 100 miles round trip. Stopped for gas to see what my first mileage numbers were during what I will call "testing phase", of more full throttle romps than I can remember. Easy numbers I didn't need a calculator for, 82 miles on the first tank, pump clicked off at 10 gallons, so 8.2 MPG. I would have liked better, and I'm sure with more normal driving like I did today and the engine breaks in, it will be above 10 MPG. With my 15 gallon tank I'll now be filling up as often as most others and their 10 gallon tanks.
More driving impressions. First, and what really stands out is the handling with the new front tires. I knew rotating mass on our light cars, when changed to something different would be noticeable, but had no idea it would be this much with nothing more than 2" taller diameter, same thread width, but thread pattern now matching the rear tire, as they are both M/T Sportsman Radials. Steering is much less effort, both slow in a parking lot and at speed on the twisty mountain roads. One hand or one finger steering through turns is sweet. As to the skid plate, it gets used a lot but is built for it. The difference from 320 HP to 526 HP for passing is huge. If I can see 400' ahead, I can easily complete the pass even if a car appears at that distance as I just begin passing the rear of the slower car. It allows for most all of my mountain road driving to be done with no traffic in front of me, and be able to enjoy the turns at the speed I want. The only and major drawback is the area of the torque curve being 1600 rpm higher than the 383. As I'm geared so tall in 5th, about the slowest I can use 5th is 70 mph and the engine prefers at 70 in 5th that the road is a little downhill. 75 mph in 5th will be OK for level road cruising, but at 65 on the mountain roads the engine is happier at 2500 rpm in 4th than 1600 in 5th. Much happier, only if the downhill is steep will I be in 5th at 65 mph. All in all, had I known the improvement in steering and handling my new tires give, I would have replaced them at the very beginning, not waiting for needing more ground clearance to go to a taller tire. The front tires I have been using and had plenty of thread were recommended by the Lotus Super 7 group, and since their front end is as light as mine, I went with their experience. The added power is still something that keeps my interest. I'm sure FatPat can identify with driving a mid 9 second street car, it is a great feeling for a gear head. Old front tires..... ![]() New tires.....
Just what Shafiroff's people said, clean bolt hole with brake cleaner, let evaporate, allow silicone sealant to skin over, run the bolt back in and let set for 2 days.
It is. Good therapy.
baby
AMEN!!!! And turned out to not be such a difficult issue afterall...although it certainly raised alot of eyebrows. Glad she's back running wild down the streets for many years to come.
From your mouth to all my engine's internals and gaskets, thank you for the positive vibes.
So did Scott ever take the time to personally answer your issue ? If not, that still isn't good customer PR at the price level of that engine...
bigdog7373. Yes I have a GoPro with camera attachments in two places on the car. Last time I posted a spirited driving video I was flamed pretty good. |
Took the Track-T out for a little romp, hwy 50 halfway to Tahoe so I could experience the passing lanes. All I can say is this kind of hp in a car so light, it is just too much fun. Traction for most all of my spirited driving has been excellent. First off, the blown '55 Ford could NEVER pull this hard, and even with a fraction of the pulling, traction was hit or miss. 1st gear still need to soft pedal, but 2nd gear is seeing some full throttle if I go into 2nd at 30 mph, then the engine is at 2200 rpm and doesn't produce enough in that low rpm to be a problem, so can be full throttle. As I hit 60 mph in 2nd, depending on road surface, I have 3 choices, if really good surface, keep my foot in it at 4400 rpm and accept some tire spin, if not an outstanding surface either roll off some or short shift. 3rd gear is good on most all surfaces except a road peak type undulation that causes un-weighing of the rear wheels, and that spin is has the highest pucker factor because of a much larger speed differential between road speed and tire speed. I know my local mountain roads well, and know where every un-weighing peak is, so no surprises.
Filled with gas again so I could check mileage. Maybe 10 full throttle romps on this tank, the rest was highway cruising pulling the grade to Tahoe and the grade from the valley back home. Drum roll................ 12.9 mpg, almost broke into the teens. As the engine seats, and I've mellowed out on pushing deep on the loud pedal, mid teens should be easy. I know the engine is still tight because when starting hot it grunts a slow 1/2 of a crank and lights off. When cold, the starter spins the engine and it quickly lights, much quicker than the 383, but that is probably from the ignition upgrade more than anything else. |
baby
Ahhhhhhhh.....now thats the ticket. Just make sure you avoid them tickets! That much go power in that light body .... better buy some stock in the local tire company! I'm sure the pucker power is thrilling! I'll bet she handles a little different with the new tires as well. Gorgeous ride! Congrats my brother on getting her out on the open road with no more problems. Enjoy it is often as time and weather will allow.
| Recent Hotrodders' Lounge posts with photos |
| just arrived | SportaboutBob | Introduce Yourself | 1 | 07-11-2007 11:00 AM |
| '51 Burb Arrived Today! | aldwaup | Introduce Yourself | 6 | 03-09-2007 10:25 PM |
| Just arrived | JACK ROBINSON | Introduce Yourself | 2 | 12-22-2006 07:34 PM |
| Just Arrived | jor | Introduce Yourself | 1 | 10-24-2006 07:41 AM |
| Just Arrived | SWIFTY1 | Introduce Yourself | 2 | 03-18-2006 08:13 PM |
