My Newest Toy (bought for 1320 fun) - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 06-27-2013, 05:10 AM
ProStreetRob's Avatar
5.7L S10 LS SS
Since my Blown Dual Quad 502 Pro Street Sierra is just to dam Mint & Flawless to be loaded, unloaded, towed, and raced, I decided to keep that for Fun on the Street and I picked up something else to beat the piss out of at the track, (and have some fun with on the street also).
Picked up this little Ranger and was drawn to it by the quality of the Build as well as the documentation and race history. I literally have a bill for ever single part on the truck, the specification of that part, and any maintenance or adjustment needed for it. I also have a log book for every single pass it's ever made and the conditions and set up for it on that day.
I wanted to make a few changes so I swapped to a Pro Rachet Shifter, a different Line Lock Button & Location, I moved the Trans Brake Button, installed a Quick Release Steering Wheel, Moved the Race Seat, new 5 Point Harness, did some general maintenance, and spent a day under it going over every single nut and bolt.
A few weeks in and I already know this truck from head to toe and feel like it's been mine forever...
Here's some pic's ...
Drove @ 1000 miles in one day to go get it
Let the modding begin...
Put the Slicks on it Saturday and took it to Atco to see what it would do first time out
And I was pleasantly surprised with the results for first time out in 90 degree heat
Old 06-27-2013, 05:19 AM
5.7L S10 LS SS
Here's the Mod List (got some REAL NICE goodies)
1987 Ford Ranger
MOTOR
351 Stroked to 418 cid (Complete Eagle Stroker Kit)
13.2:1 Compression
Forged Eagle 4340 Crank
Forged Eagle 4340 H-Beam Rods
7/16" ARP 8740 Rod Bolts
Forged Mahle Pistons
Premium Moly File Fit Rings
Clevite 77 Main and Rod Bearings
Fluidampr Harmonic Damper SFI 18.1 # H145279
Canfield Aluminum Heads (Stage III) Fully CNC Machined
Full Intake Porting
Reshaped Chambers to Enhance Flow
Polished Combustion Chambers
Stainless Steel Valves
Manley Chrome-Moly Retainers and Locks
Viton Valve Stem Seals
Isky Double Valve Springs
Relocated Intake and Exhaust Valves for Improved Flow
Raised Exhaust Port (.400 of an inch)
Comp Cam Solid Roller #35-803-9 (.672 Lift Intake/Exhaust, 296/300 Duration @.020)
Aluminum Roller Rockers (Valve Adjustment= .020 Intake / .022 Exhaust)
Canfield Stud Girdle Kit #SGF-1L
TRANSMISSION
Fully Built BTE C-4 Transmission
CSI Certified Scatter Shield A105409 #CSI-825B
BTE Reverse Pattern Trans Brake Valve Body #421500
BTE 5500 RPM Stall Converter
TCI Certified Flywheel #529628
B & M Mega Shifter #80680 B & M Pro Ratchet Shifter #80842
TCI Line Lock #861700
REAR/SUSPENSION
Narrowed 8.8 Rear
Detroit C-Locker Model 187C-147A Part #71094
4:88 Richmond Gears
28 Spline Strange Axles
S&W Race Car Adjustable Ladder Bars
S&W Race Car Coil Over Springs #50-035
6 Point Roll Bar w/Swing Arms Door Bars on Both Sides
FUEL SYSTEM
Edelbrock Victor Manifold
Ruppert Holley Modified 850cfm Carburetor
HVH 2 Super Sucker Spacer #SS4150-2
Aeromotive A-1000 Fuel Pump
Aeromotive Fuel Pressure Regulator #13204
Aeromotive Fuel Filter
6AN & 8AN Steel Braided Lines & Fittings
15 Gallon Stainless Steel Foam Filled Fuel Cell (Bed Mounted)
IGNITION
MSD Pro Billet Distributor #8478
MSD #8467 Rotor
MSD #8431 Cap
MSD #8841 8MM Spark Plug Wires
MSD Blaster Coil #8227
MSD 6AL Ignition Box
MSD #8984 Starter Saver (retards timing when starting)
MSD #8737 3 Step Module (using it as a 2 step, 3000 RPM / 8000 RPM)
EXHAUST
Custom Kromer Kraft Cermamic Coated Step Headers
Custom Bolt On / Off Magnaflow Cermaic Coated Exhaust System
COOLING
4 Core Aluminum Radiator #716683
(2) Flex-a-lite w/ Twin Electric Fans
CSR Electric Water Pump
External Transmission Cooler w/ Fan
TIRES/WHEELS
(2) Weld Prostar Alum Polished Wheels #WLD-96-512210, (15x12, 5x4.50, 5.50 BS)
(2) Weld Prostar Alum Polished Wheels #WLD-96-510210, (15x10, 5x4.50, 5.50 BS)
(2) Weld Prostar Alum Polished Wheels #WLD-96-55206, (15x5, 5x4.50, 3.50 BS)
(2) Mickey Thompson Sportsman 29x15.5 15LT Rear Street Tires
(2) Mickey Thompson ET Drag 28x11.5 15 Rear Drag Slicks
(2) Mickey Thompson Sportsman 26 x 7.5 15LT Front Runners
GAUGES
Auto Meter 10,000 RPM Monster Tach
Pro Form Shift Light
Auto Meter Water Temp Gauge
Auto Meter Transmission Temp Gauge
Auto Meter Oil Pressure Gauge
OTHER
Grant 3025 Quick Release Steering Wheel Hub
Grant 673 Steering Wheel
G-Force 6000BK 5 Point Harness
Harwood Fiberglass Bolt-On Aero Scoops #HRD-4163
Harwood Hood Plug #HRD-2001
Custom Fabricated Aluminum Bed Cover (3 pieces with zues fittings)
Optima Battery
Ok i bought a new toy.. decided to share.. Sata RP related beemdubya Body - Exterior 52 02-03-2010 05:41 PM
NHRA now will run 1000' instead 1320' scrot Hotrodders' Lounge 33 07-07-2008 12:58 AM
Bought a new toy yesterday!!! Half Breed Hotrodding Basics 4 02-10-2006 08:29 PM
Bought a new toy Robinson Robin Hotrodders' Lounge 5 05-06-2004 09:04 PM
WEIMER'S Newest Toy Weimer Hotrodders' Lounge 14 01-26-2004 12:35 AM
