The Critter gun will not shoot Top and Trim adhesive, it's too thick. It will only shoot foam to foam glue which is thinner. You can do everything in a car interior with Top and Trim adhesive, but you can't do everything with foam to foam glue. At some point you will need a separate gun to shoot Top and Trim adhesive also.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 05-12-2011 at 01:04 AM. |
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 05-31-2011 at 02:55 AM. |
It's even later now.
Got the seatbases on the front seat pretty well done. I had to cheat a little putting the listings on. I sewed thm on after I finished the top cushion. It was to much for me to sew them on at the same time I was sewing the top cushion together. I ended up with a little fabric clot where the listng seam intercepts the cushion to facing seam and a little bit of a jagged edge in the corner. All in all I feel pretty good about it
I removed the driver side seat cover and found a bit of damage to the underlying foam. Short of refoaming would this be a good place for a foam patch. It is maybe 1/4 in. rubbed off. Maybe I should just leave it alone
Another area I am struggling with is topstitching the cushion to the facing. Is it permissable to lightly glue the selvadge to the facing before stitching. I have not overlapped or ran over the initial seam yet but the stitiching is not real parallel to the original seam.........Steve
| Recent Interior posts with photos |
| Different new project? | Formula_Dave7 | Engine | 5 | 11-21-2007 09:34 PM |
| old project | jrs55 | Introduce Yourself | 1 | 10-20-2007 05:50 AM |
| about my project... | trevy | Introduce Yourself | 2 | 09-18-2007 06:42 AM |
| 1st project | Terry411 | Suspension - Brakes - Steering | 8 | 04-26-2005 07:29 PM |
