__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
You would almost never top stitch to the seat top, but there's no rule that says you can't if you like the look. The stitching would be in the perimeter pieces attached to the seat top.
Relief cuts are normally cut in as you go and where needed, so that would be before you top stitch. I rarely make relief cuts if I'm planning on top stitching, especially in vinyl, leather, or Ultraleather which stretch more than cloth fabric. The exception to that would be a really tight corner.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 05-30-2011 at 04:43 AM. |
That's a pretty large pucker in a small area. Where did you start sewing the perimeter pieces to the face of the seat back? Are you making a lot of witness marks on the two pieces you're sewing together and trying to match them up as you go?
Started almost at the center of the headrest, went through center and down about a foot. I then we nt back to the center of the headrest and went the opposite direction and down about a foot. I then did the sides in two sections from the bottom to the center and then from the first seam down. I had witness mark where the seams on the perimeter piece, it is made from three peices, intersected the cushion top.
A couple things to remember about witness marks: First, too many witness marks are not a good idea. If you try to force the fabric to match up between witness marks when they aren't lining up, you can create puckers. Second, the witness marks on a cloth seat cover may not work out the same if you are doing the seat cover out of vinyl because the vinyl stretches a lot more than the cloth.
The smoother and flatter you sew the seat cover, the better it will fit. You would be better off to start from the top middle and just sew continuously to the end in both directions. Leave the outside pieces long and cut them to fit at the end. This will leave you with a much smoother seat cover.
Thanx. I think I need to work on the smoother and flatter concept. I was really fightin the machine and had a bit of problem keeping the peripheral and cushion peices lined up on the edges passing through the corners as they are relatively tight.......Steve
was able to get the second one completed today. All in all I am pretty happy with the outcome. They look better than they have since 1990. I have a couple wrinkles where the listing is held down but i am pretty certain I could have done worse. I feel alot further along than when I started the laearning a couple years ago. I will do the back seat eventually.........Steve
| Recent Interior posts with photos |
| Different new project? | Formula_Dave7 | Engine | 5 | 11-21-2007 09:34 PM |
| old project | jrs55 | Introduce Yourself | 1 | 10-20-2007 05:50 AM |
| about my project... | trevy | Introduce Yourself | 2 | 09-18-2007 06:42 AM |
| 1st project | Terry411 | Suspension - Brakes - Steering | 8 | 04-26-2005 07:29 PM |
