Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - my paint is peeling where do i start
  #23 (permalink)
Old 11-23-2012, 11:45 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by mr4speed View Post
Brian, good call on the stripping of hoods, and roofs, and I will also add trunk lids as well. I don't know about any one else out there but I have had a tough time stripping the inside of hoods and trunk lids even using a wire wheel. The heat from this is enough to completely destroy a nice straight panel. The other way to destroy for sure is sandblasting the insides of these panels. It is very hard to believe that the little bit of heat from these stripping techniques will damage anything, but just beware it will for sure.
This is so true, let alone the heat problem that go along with trying to get into the little recesses and underneath braces...the cuts to your hands, or ripping up a perfectly good sanding pad when you catch an edge.
Thanks for posting this information Mr.4 speed
