is it my power steering pump. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 10:01 PM
briansansone's Avatar
4 chevys and a ford
Not much of a hotrodding question, but...
How can I know if my power steering pump, or steering gear, or both
are going out?
My 2000 Ford Windstar makes a loud winning/grinding noise as I turn the
wheel. The resevior was a little low when I checked it. The fluid seemed to be moving pretty good. I could see the return fluid pouring into the resevior.
Though it was very dirty, and seemed very thin.
Replacing the pump looks pretty easy. Replacing the steering gear requires
removing the sub frame, engine hoist, etc....
Thanks!!
Old 08-08-2010, 06:38 PM
LATECH's Avatar
Last journal entry: New Gas Tank
are going out?
Thanks!!
It is niether pump nor rack . it is trapped air in the hose. Go to the blue oval place and get a new hose assembly part number YF2Z-3A719--AA and install it. It has a Pulse dampener and will require you to perform a bleeding procedure . This will require a vacuum pump for this procedure . You will need to pull 20 inches of vacuum on the system with the engine running to get the air out and you may have to do this a few times for 4-5 minutes at a time.Pulling a vacuum on the system causes the air in the system to expand and it moves it to the reservoir where it escapes.steering fluid will not vaporize at 20 inches of vacuum but water will. Hope this helps
Old 08-08-2010, 06:39 PM
LATECH's Avatar
I would flush the fluid as well as you will be into the system to start with so might as well do it right.
Old 08-09-2010, 06:28 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I have made a vacuum adapter for those, out of a salvage yard P/S cap, and attaching it to a manifold vacuum fitting on the motor, teeing into an existing hose if need be. When I do a pump in any kind of Ford, I use that cap, sometimes even leaving it on the vehicle for a day or two and having the customer return to replace their original cap.
Old 08-10-2010, 08:24 PM
4 chevys and a ford
Why do you believe its this one particular part? The van does have 150000 miles,
but the fluid seems to move pretty fast through the system. Does that not rule
out an air lock?
Thanks
Old 08-10-2010, 08:48 PM
LATECH's Avatar
No. if it has the noise like you described it has an air lock. It is possible at this many miles(did not realize it had so many) that the pump is either sucking a little air in past the front seal or the fluid is so degraded that the pump is cavitating. Did you ever change the fluid? I would start there and perform the bleed procedure.
Old 08-10-2010, 08:57 PM
4 chevys and a ford
only had the van a little while. got it from mother in law.
I'll get the fluid flushed and then refill, see what happens. I'm afraid to run
out and buy a pump prematurely. If the rack is having issues, i'll probably
look into getting rid of the van.
Thanks!
I'll post back
Old 08-11-2010, 05:57 AM
Rickracer's Avatar
BTW, Fords with screaming P/S pumps are not terribly unusual,
Old 08-11-2010, 06:13 AM
LATECH's Avatar
Yes they can be a pain in the buns.I have used a little lucas steering additive (some) not a whole bottle to help with pump noise and it helps to quiet them sometimes It does seem to help in some cases.I do not like to use additives nor do i prefer to advocate them but sometimes the budget kinda mandates to go the cheap easy way , its a crap shoot at best, but in your case worth a try. lucas power steering stop leak and additive.
The trouble with stop leak is it affects ALL the rubber pieces in the system not just the one with the problem ,as with any additive .There is no substitute for good old fashioned maintenance on a regular basis.
I can understand people not doing some kinds of maintenance because they just dont know for sure is it neccesary and some places want to sell you all kinds of B S so people get gun shy and do nothing.believe it or not brake fluid and power sterring fluid do need flushed and changed every so often. I do not recommend an engine flush EVER.Coolant should be flushed every 2 -3 years and freshened up no less than every 2 years.
Old 08-12-2010, 12:40 PM
4 chevys and a ford
got some relief
after pulling the van up on ramps, I found a leak on the steering rack.
In an effort to prolong the life and get some functionality back,
I drained the system ( as much as I could by routing the return line
into a container and turning the wheel back and forth ), then tried the
ever so popular lucus stop leak and some fresh fluid. One day later; so
far so good. It seems that the leak has at least drastically slowed, and
the steering once again works fine.
We'll see just how long I can get away with the cheap fix.
Thanks
Old 08-12-2010, 05:56 PM
LATECH's Avatar
You Da Man
Old 08-12-2010, 06:49 PM
4 chevys and a ford
Well that went great! I got one more day out of rack. I'll be gearing up to
jack the van up and replace the rack.
Old 08-12-2010, 07:45 PM
LATECH's Avatar
Oh man . That sucks. At least it failed when the wife wasn't driving. Could be a lot worse.Best of luck.
Power steering pump on blown motor Marcus Engine 14 05-16-2008 01:10 AM
1971 chevy 350 power steering pump colincamaro Suspension - Brakes - Steering 10 12-27-2006 01:14 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
