Is my rear end gear pattern ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2007, 09:20 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I got my posi and 3.73 gears in. When I first put them in and checked the pattern it was right in the center it seemed. I finished it up, drove lighty for about 3 days, then opened it back up to change fluid and take a look. The pattern left on the gear seems alittle low to me (inwards toward the center of the ring gear). I made it clear highlighted in the last photo. The gears are relativly quiet with a slight hum somtimes. Also, after driving for a bit, on turns, it makes a waa ooo waa ooo waa ooo type of noise, is that just the posi? (72 nova 10 bolt 8.5")
Thanks
Old 04-22-2007, 10:34 PM
Yuo are showing mostly the coast side of the ring gear. Show more of the drive side and we can tell more.
gcrmcc
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
rear end / brakes, etc / INFO?? Pickup Guy Hotrodding Basics 7 08-02-2007 02:06 PM
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 01:53 PM
Converting to posi... rear end and gear ratio? Street Rod Transmission - Rearend 3 01-21-2007 08:31 PM
1972 Olds rear end gear ratio jpd37 Transmission - Rearend 4 09-26-2003 04:59 PM
