Are my rims too big? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2006, 02:44 PM
1971 Chevy Nova
I have a 1971 chevy nova, and I purchased a set of 17 x 8" Craiger SS's. I have the correct spacer for them, but I am afraid they will rub on sharp turns when I mount the tires. Does anyone know what size tires I should use to prevent rubbing?
Old 02-01-2006, 03:46 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
A good tire shop should be able to help you out with that.
Old 02-02-2006, 08:21 AM
My '72 Nova sits a little low, and 225/60-15's (on 15x7 Rallys) rub on the center front fender-well bolt head. I removed it, and now it just barely keeps the surrounding area shiny. They also keep a small portion of the sub-frame shiny toward the rear, but that only rubs with the wheel at or near full-lock. I also bent the rear wheel-well lips upward so the rears won't get cut, but that might not have been absolutely necessary.
Old 02-02-2006, 01:24 PM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
I have a 265-60-15 in the back, and they rub with 1/2 tank of gas. Depends on your offset too. Mine JUST barely miss the flanges.
Custom Made Rims.... 53fordguy General Rodding Tech 11 11-21-2004 09:58 AM
Big cars Wmarden Hotrodders' Lounge 16 09-12-2004 09:05 AM
20" rims on a 1972 chevelle 350? MYNAMEIZCARLOS Hotrodders' Lounge 50 11-04-2003 10:50 AM
Big Mack Kevin45 Hotrodders' Lounge 0 12-08-2002 01:33 PM
big tires? cannedheat Body - Exterior 6 10-16-2002 01:35 AM
