#166
I don't see it being a problem. Come check it out in person if you wish.
Register now (free) or login to remove ads |
#167
Forget I said anything, you have done a STUNNING job for a guy of any age let alone an 18 year old. You should be VERY proud of that truck. I can't wait to see the rest of it.
Brian |
#168
I finally worked up the corage to look at this HUGE thread, glad I did
Pretty interesting fabrication ( in a good way) How did you bend the tubing? they look like custom bends but it's hard to tell. Oh, and I like the I4, it cool. You're building a lowrider not a racecar, Low riders cruise, slowly.... did you ever get it to run? |
#169
Thanks for checking it out! I bent the tubing with a hydraulic tubing bender. The wishbone I had bent because I don't have a 1.5" die. I did get it to run, but its failed smog 3 times. Probably going to fail again this Wednesday, but I've got to try. Its been hell trying to make it pass. |
#170
Same goes for me aswell I shaved off the handles, emblems, antenna. My baby is clean aswell, sometimes haha. I still have not gone through all the posts but from what i have seen you have done some amazing work. Good job!!! |
#172
Couldn't you just slip the guy a C-note at the smog station and be done with it?
Who said that???!!! John |
#173
Thats getting riskier here in CA. A guy I knew lost his license last year for it. Also, an illegal smog starts at $300 here. They'll laugh at you if you offer anything less.
Also more money than I have to spend right now. |
#174
Versus an impound? John |
#175
Beginnings of a nice ride
Just wanted to give you a few more words of encouragement, my husband didn't start his mini until he was 29, but it became his passion for more than the next 15 years. The only reason he's moving on to something bigger (a '51 Suburban) is a bigger family and we really don't fit in with the subcompact and mini crowd at shows much anymore. He's done a lot of judging on the east coast, and has been in a number of mini mag's "back in the day" if you have any questions his mini is still his first love, and we just wanted to say your off to a real good start! Good luck, nice ride! (BTW...The attachment is Mark's truck at all truck nationals last year at Carlisle)
#176
When you put the carb on the first time did you do anything to it prior to install? The reason I ask is because you may have the wrong jets along with fuel pressure! There is a place in L.A. that imports japanese engines. Don't remember the name but you might want to give them a call. They may have the carb your looking for.Do you have to use that particular carb? Can't you use somethng else in the meantime and just get it to pass smog?
John |
#177
I'm no engineer, but I have been building stuff for years that works. I was looking at the design for a while, I see some interesting design aspects, that are certainly put there for the look factor, but I think there is more than enough material there to do the job. In all reality, the forward tube that goes up from the bag mounting plate and lands on the crossmember at the top of the "C" notch structure would do the job by itself with a small strut to the rear to stabilize it. He has that in his design plus some. I like simple, straightforward designs myself, but if a guy wants to make it look different and still do the job, my hat's off to him. Hope you get your smog sorted out. Can you borrow a carb? later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
#178
I can't afford an impound either. I'm in debt from trying to get it to pass already. I can't run a different carb due to smog laws. I may be borrowing a friends 22R carb tonight to try to see if I can make it believable. |
#179
Thanks Mikey, I stand corrected. Brian |
#180
I'm bringing it to a show in Visalia this weekend. I know there were a couple people on here in that area. So if anyone wants to check it out, its a fun show. Theres usually a good number of hotrods and muscle cars in attendance.
| Thread Tools | Search this Thread |
| Similar Threads for: "My Rolling Chassis" | ||||
| Rolling chassis | oldred | Body - Exterior | 3 | 06-14-2006 03:50 PM |
| Kit cars and rolling chassis? | Riot Racing | Hotrodders' Lounge | 9 | 04-29-2006 11:44 AM |
| First stage of rebuild, chassis first? | Oz GMHR | General Rodding Tech | 6 | 06-26-2005 12:36 PM |
| Who can ship a rolling chassis??? | rokbrnc | Hotrodders' Lounge | 2 | 04-27-2005 01:17 AM |
| HELP! New 32 Ford chassis issue | RoadShow | Body - Exterior | 8 | 06-30-2004 07:50 PM |
