my sata nr 95 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2006, 11:24 PM
my sata nr 95
I bought a sata nr 95 hvlp paint gun with a 1.3 mm tip off my buddy for $150 and it was used 3 times becuse i know when he bought it but i dont no how to set it up . I wont to no if the gun is good for basecoat clearcoat and what elsethe gun is good for
Old 06-12-2006, 12:41 AM
milo's Avatar
point on positive
you got a very good deal...
run some thinner through it and see how it sprays...
Start by opening the fluid knob 2 1/2 turns and then turn the fan control knob until a uniform shape hits the panel or test panel while fully pulling the trigger...
Old 06-12-2006, 08:47 PM
nr 95
I wont to know what psi shoud i be runing for basecoat and clearcoat.
Old 06-13-2006, 01:08 AM
milo's Avatar
point on positive
At the gun about 30psi would be a place to adjust from.
Old 06-13-2006, 10:14 PM
thanks for the help on that. I was looking for a good primer gun do you have any suggestion on a good brand
Old 06-13-2006, 11:57 PM
milo's Avatar
point on positive
Did you get it to spray?
That is a good gun for primer as well as paint and clear..
A primer gun used to be the gun that just sat with primer in it all the time when laqure primer was abundant. The idea was if you keep primer in the gun you didn't have to clean it.. it was always ready to primer something. Along came the use of epoxy primers and now you have to clean it every time, so ,, if you have to clean everytime ,,, .. might as well use the "good" gun... So the good gun becomes the primer gun and now everthing get's sprayed through the good gun.. The up side to useing one good gun is you learn how the gun sprays before you put paint in it during the priming ...
heres a thread might help , i need a good paint gun
Old 06-14-2006, 11:15 PM
sata 95
yes i got the gun to spray good but with a 1.3mm tip i cant use my hi build primer. I trird to use the hi build but it just splattered because i need a 1.6mm 1.7mm or 1.8mm with my hi build . I wont to know if i can get parts for it because my buddy lost the wrench and the cleaning kit that he got with it and i wont to get the biger tips so i can use my gun for the hi build .
Ingersol Rand Paint Gun Like Sata 2000?? camaro freak Body - Exterior 1 05-13-2006 02:22 PM
94 to 95 Ford Taurus engine and trans swap 406chevelle Engine 6 11-20-2005 03:14 PM
95 GEO PRISM Noises. 1Fast65Elky Transmission - Rearend 1 07-29-2005 09:22 PM
95 Camaro engine swap torqjunki Introduce Yourself 1 12-18-2004 12:45 PM
Nr 6E and Nr 8I not rotating zardiw Engine 3 07-14-2002 04:30 PM
