MY SBC 400 DYNO Yesterday WOW, WOW, WOW - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2004, 04:35 PM
84 Z28 Convertible
First I would like to thank everyone for their advice and help getting me through this rebuild. I could not have done it and achived the results without your help.Thanks a Millions....
Here are a few number from my dyno yesterday, I will scan and post later the actual dyno sheets. We made about ten pulls after breakin and I was glad to spend the $300.00 for what I found and learned yesterday. The engine combo is in my signature.
Pull #A1967
Carb:4779
timing: 34
Dist:msd 85551
4300 rpm: 502.4 tq
5800 rpm: 464.9 hp
Pull #A1963
Carb:4779
timing: 32
Dist:msd 85551
4300 rpm: 495.4 tq
5600 rpm: 455.2 hp
Pull #A1963
Carb:4779
timing: 34
Dist:msd 85551
4300 rpm: 502.4 tq
5800 rpm: 464.9 hp
Pull #A1973
Carb:3310
timing: 36
Dist: H.E.I.
4600 rpm: 484.0 tq
5600 rpm: 466.5 hp
Pull #A1970/b]
Carb:3310
timing: 36
Dist:msd 85551
4700 rpm: 479.3tq
5600 rpm: 459.2 hp
Pull #A1971/b]
Carb:3310
timing: 37
Dist:HEI
4600 rpm: 481.3tq
5700 rpm: 457.5
The double pumper 4779 out perform the 3310 throughout the entire pull. Lost about 25# of tq with just a carb change.
At 5000 rpm's with the HEI and 3310 we had 471.8 tq and 449 hp and 6000 rpm's with the HEI and 3310 we had 402.5 tq and 459 hp.
She was still pulling at 6489 rpm with 352 tq and 434 hp.
Thanks everyone, but I need a double pumper with staright out the box 70/80 jets what his carb had...
The average fuel F #/Hr was:
3310-173.8
4779-163.5
The smaller carb required more fuel
Old 07-02-2004, 04:38 PM
84 Z28 Convertible
Here she is on the $300.00 Dyno: I had my engine their from 0830 am til 0630 pm, $300.00 well spent....
Old 07-02-2004, 05:36 PM
4 Jaw Chuck's Avatar
Very nicely done, hope this will solve the silly vacuum secondary/double pumper comparison argument that pops up from time to time.. To make torque you need fuel.
Very respectable numbers.
Outlawed tunes from outlawed pipes
Old 07-02-2004, 06:43 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Ditto with Chuck.
Congrats on getting the motor running with some good numbers.
Luv the smell of NITRO in the morning.
Old 07-02-2004, 06:58 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Great numbers. How about reminding those of us who dont remember your combo.
Chris
Old 07-02-2004, 08:00 PM
Grumpy
Nice, stick a Q-jet on it and see what happens
But $300!!! Jezzz.. only costs about $75.00 here.
Old 07-02-2004, 08:23 PM
84 Z28 Convertible
Wow
You can have your engine on a Dyno for 8 hrs and only cost $75.00, that shop must have very little overhead and little paychecks.
Chris
My Cr: was 10:48.1 according to Pat Kelley Calculator and quench of .041.
Here is my complete Combo Mostly every part was new, so it can be done cheaper. The only parts I orginally used of my old engine was the Edelbrock RPM and H.E.I Distributor w/ MSD Module and Accell coil, cap and rotor. This is a 95% street car...
We also use his headers because my tight shorty clearance headers would not clear the bellhousing on the dyno stand, His headers was the 1-3/4.
SBC 408 PARTS and PRICES
MANUFACTURE DESCRIPTION PART# PRICE
AFR Heads 195cc AFR-1036 $1,425.00
ARP
Main Studs ARP-234-5501 $51.95
Head Bolts ARP-134-3701 $58.95
Oil Pump Stud ARP-230-7002 $6.50
Oil Pump Shaft ARP-134-7901 $13.95
Fuel Pump Pushrod ARP-134-8701 $14.95
Cam Bolt Kits ARP-134-1001 $3.95
Fuel Pump Bolt Kit ARP-430-1601 $7.88
CARTER
Fuel Pump 12 CRT-M6900 $59.95
CLEVITE
Main Bearing MS1038H $55.00
Rod Bearing 8-CB663H $55.00
CLOYES
True Roller Timing Chain CLO-9-3100 $60.09
CRANE
Energizer Roller Rocker CRN-11744-16 $132.50
EAGLE
H-Beam Rods CRS6000B3D $335.09
EDELBROCK
Elite Air Cleaner EDL-4207 $49.88
Valve Covers Tall w/ Script EDL-4249 $69.95
ELGIN
Solid Lifters VT1992-16 $50.00
FEDERAL MOGUL
Cam Bearings 1235M $19.00
FEL-PRO
Head Gasket FPP-1014 (2x) $63.90
Intake Gasket FPP-1205 $13.95
Rear Main Seal Align Bored FPP-2909 $18.95
GRIFFIN Radiator
31"X19" $159.95 Radiator Cap 14-16 lbs $10.95
HOLLEY
Carburetors 750 VAC. SEC. HLY-0-3310S $249.95
Fuel Regulator HLY- 501 $26.00
Fuel Line HLY-0-34160 $20.81
LUNATI
Flat Tappet Mechanical LUN-280/284F10 $183.71
Dual Valve Spring LUN- 73124 $101.59
MILODON
Oil Pump Pick-Up Screen MIL-18311 $34.95
Milodon Street/Strip Oil Pans MIL-30900 $123.49
Diamond Stripper Windage Tray MIL-32250 $74.95
Lifter Valley Screen Kits MIL-23150 $15.95
Oil Pan Baffle MIL-32500 $5.25
Lifter Valley Baffle MIL-32610 $29.95
MELLING
Oil Pump MEL-M55 $13.95
MR. GASKET
Oil Pump High Press Spring MRG-26 $3.95
Brass Freeze Plugs SBC 400 $14.95
Fuel Pump Mounting Plate MRG-1514 $4.88
PIONEER
Harmonic Balancer 8" Int.Bal. PIO-872003 $95.88
Flexplate 168 tooth FRA-100 $34.50
RUSSELL
Clear Fuel Filter RUS-645470 $14.88
SCAT
4340 Forge Crankshaft 4-400-3750-6000 $490.00
Stewart
Water Pump 23113 $159.95
180* Thermastat 301 $10.95
Bolt Kit 102 $8.95
Water Pump Spacer Spacer $3.95
SUMMIT
Fuel Pressure Guage SUM-800115 $19.95
Timing Cover Bolt Set SUM-G1574HS $2.69
WISECO
Pro Tru Forged Pistons PT020H4 (0.040) $419.00
TOTAL COST $4,902.32
Engine Parts Total $4,710.61
Engine Machine Work Total $954.00
$5,664.61
Here is a few photostake during the dyno:
DYNO PICTURES
Old 07-02-2004, 11:05 PM
Jmark's Avatar
PIcture link doesn't work. Yahoo/Geocities blocks images used outside of their own site. Oh well.
Old 07-03-2004, 12:04 AM
84 Z28 Convertible
It should work now I forgot to make it public.
Old 07-03-2004, 12:18 AM
Grumpy
No,no,no... $75.00 for 3 dyno runs. Not 8 hours worth of runs heh. Did'nt know you had it on there that long.
Heh, that just doesnt sound right "Not 8 hours worth of runs" but I think I'll leave it
