are my secondary butterflies opening? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2006, 11:20 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
is there a way to "see" if they open fully under heavy load?
600 cfm Holey 4160, vaccum secondaries.
I feel a smooth aceleration curve but have my doubts, I used the bolt in the slot trick to force them open but it reacted adversly, it bogged down I guess because there is no fuel shot like in the double pumpers.
Any ideas?
Augusto.
Old 10-28-2006, 11:47 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Take the hood off and the air cleaner off and watch it. You might want to tape a mirror on the carb if its too high to see from the driver's seat.
Old 10-28-2006, 01:49 PM
I put a plastic tyrap on the secondary shaft. I then cut the end of the tyrap so it would hit the carb base and slip on the shaft as the secondary moved. After a test run I could see how much it opened buy the angle of the tyrap end. Just put the rap on loose enough to move. Vacuum secondarys will not open by reving the motor in neutral. The vacuum comes from a small port in the primary barrel and has to have a large amount of air going by to creat the vacuum for the seconday opening.
Old 10-29-2006, 08:09 PM
Augusto's Avatar
q-jet secondaries do open with the car not running, ( and sounds awsome ) but holley's are a puzzle to me, I was thinking of installing a TPS sensor and a voltage meter to monitor them, has anybody ever done it before?
Augusto.
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Power loss with vacuum secondaries? Mad Maggot Engine 22 08-01-2005 09:31 AM
Rich idle Trav Engine 26 11-03-2003 09:42 PM
secondary spring 69 chevelle SS Engine 2 09-11-2003 05:50 PM
