Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is my set up going to be ok
Old 03-10-2013, 01:46 AM
thinwhiteduke's Avatar
thinwhiteduke thinwhiteduke is offline
Living In The Past
Originally Posted by Motosledneck 12 View Post
While searching this setup I found a a post saying this cam with more then 9:1 does not have enough duration to bleed off cylinder pressure for the upped compression. Just wondering if this is something I have to worry about. Thanks for your reply.
IMO you don't have enough cam timing to support your static compression ratio, if you have a true 10.38:1
Check out the attachment below..
Duke
