are you saying you have 18 degrees initial timing -- if so that seems to much for me-- -- more like 10 or 12 degrees should be in the Ball park and about 36 with full advance--just my op ion
[QUOTE]From Rich27028:
http://www.hotrodders.com/forum/oil-level-158150.html It's like, are you kidding me? Good for a chuckle anyway.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
hey i didnt save that thread -- it was a good joke while it lasted--
what was nice was every one was a gentelman and didnt go off the deep end --that evening the mod called me and ask if i had a son and was my car ok-- some times we take life to serious and its fun to pull some ones chain -- i was serious about his timing --its to far advanced- and his motor should not shake all over the engine bay-- and good lope is different than shakeing-- id be worryed about the kicking back on the starter-- Last edited by Rich27028; 05-10-2009 at 05:06 AM. |
The fact it will fire right up with no Choke on the coldest day means to me she is way rich.How much of your idle transfer slots are exposed at the base idle setting? They should appear square when looking from under the carb not have the blades open so far they appear rectangular. It sounds like with your cam you have the throttle blades opened to far in order to get an acceptable idle causing it to be pulling fuel from the main metering circuit instead of just the idle cicuit.
When I say that it fires up, keep in mind I have to give it a pump of gas and hold the pedal down partly or she'll stall until warmed up. But it will start in a second and so long as I keep the rpm high enough it wont stall until warm and then I can idle at 900rpm or so. I gotta pull the carb and see whats doing from underneath. At least its 1 less thing to guess about |
If my wife knew I snuck into the garage on MOTHERS DAY I'd be dead.
Anyway, here's the pic which is hard to view because I cant focus on the openings: ![]() The openings are NOT square and if I had to guess Id say theyre way over .070 or more. I think .040 is the ideal? Theyre not hugely rectangle but you can see the left side one a little better than the right. I wish I could get a better pic and will try. But Id say its close to twice "long" on the opening as it is wide. Follow me? |
Tried to pull some detail up on the image:
I got a better pic, hope it has more detail than the enhanced one above
![]() You can see the long opening and theres also a tiny tiny little round hole just above the plate which, if my openings were SQUARE, would be covered I think. In the photo, the left plate, you see the rectangular opening and to the RIGHT of that is a little shiny spot. Thats the little opening which would NOT be exposed. Looks like I got issues here?? lol |
Maybe just my eyes. Lightened and contrasted:
The puzzle comes together now: I remember I used to have the idle timing at FULL ADVANCE of 38' before I installed the MSD computer for timing. It was hell on the starter but the car never had a problem. A few years back I installed the MSD computer, keeping the locked out timing of 38', but the computer can control the idle time which I have at 18 or 20'. With the lower timing I remember I had to bump up the idle screw and thats partly why Im too rich now
So, this week I think I'll just adjust the MSD computer to give me 38' timing at idle (the car never pings), then lower the idle speed screw, remove the carb, and see where I am?? YES or NO? Or should I do the old trick of holes in the plates or fiddle with the secondaries to let more air in?? Which way is better? Old rule was "get the highest possible timing you can without detonation" and I know I can go beyond 40' with no problem. 38' was recommended |
Close the primaries till they are approx. square, open the secondaries slightly and try it before drilling the blades.A lot easier to drill out material than put it back in. Does you timing box have a start retard feature if so you could lock the timing and use it to start it to keep from hurting starters.
the MSD has a built in 20' start retard. I'm at 18' start no matter what because I'm locked at 38'
Once I set the plate back to where it's supposed to be, then adjust secondaries, where do I get my increase in idle rpm from? I'm exactly 1 full turn less on the idle screw to get the plate back. Is advancing my timing my only means of raising the idle speed? It's no issue I just want to confirm it as such. Or will the secondaries be taking care of the needed rpm?? |
Bogie |
This post probably needs a new title since its all carb at this point. lol. Heres whats happening:
I lowered the idle screw until I got a square hole. I could remove the screw and still have the hole the same size so at least NO IDLE screw pressure is a good starting point without removing the carb again I then adjusted the little secondary screw under the carb (small inset screw). I turned it 1 full turn as a test and reinstalled the carb Car starts easily, seems to have no kickback, but unless I dive out from the drivers seat to give some throttle shes gonna stall. Anything under 2000rpm seems to idle like total crap and she'll stall at whatever idle speed its set down to. I estimate its at 500rpm. I did not yet increase my timing at idle which is 18' If I increase the secondary openings (I can move the plates manually from the side of the carb) I can raise my idle rpm so she wont stall. This is the same as turning the screw under the carb without actually doing so. If I adjust the idle screw it also does the same BUT that defeats the purpose here since I want to keep my plate where they are. So, should I increase the secondary openings MORE (which is sucking in more gas to do so) until I get a good idle or should I raise my idle timing more? Or both? |
| spark plug length | jeepers creepers | Engine | 5 | 05-09-2009 10:02 AM |
| Ignition system info................ | poncho62 | Electrical | 18 | 10-11-2008 10:10 PM |
| Making your own spark plug cables | intergalactica | Electrical | 8 | 10-06-2008 09:12 AM |
| Spark Plug brands question | Francis | Engine | 65 | 07-15-2008 12:01 AM |
| Top of spark plug broke off!! | HotRodMan | Engine | 7 | 03-06-2008 09:13 PM |
