You can clean them with a wire brush. Get most of the black carbon off and then use 220 grit sandpaper to clean the area where the spark happens. Finish by blowing the loose material away with compressed air.
Are all of your plugs black or just a couple? If they are all black then you are probably running too rich and need adjustments to your carb. If only a couple are black it may be other problems.
