Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My SPARK PLUGS keep burning out on me after a quick drive.
Old 03-24-2010, 06:26 AM
Rickracer's Avatar
Rickracer Rickracer is offline
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
If your plugs are gas fouling, it doesn't matter which plugs you use, if even if your ignition is nuclear fission powered, it's still gonna foul them. Like Techinspector said, gotta get your carb and fuel pressure sorted out. I seriously doubt your timing is helping either. With that cam, you probably gonna want about 12° to 14° of initial timing. I'd definitely do that next, then bead blast or replace your plugs, and see what's up with the carb/fuel pressure.
