My SPARK PLUGS keep burning out on me after a quick drive. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-26-2010, 05:44 AM
sqzbox's Avatar
My pipes are my music
flooding
Good deal, glad to hear you got her fixed. I don't know how long this has been going on but, might want to think about changing the oil. Raw gas dripping down the intake finds it's way into the oil pan, contaminating the oil.
I've heard a lot about "vacuum controlled fuel pressure regulators" That reduce pressure at idle (high vacuum) and cruise and increase pressure under load and WOT (low vacuum) mostly from guy's with TBI and port injection. Not sure about carbs though. I'm curios about what you got as I'm looking to upgrade my fuel pump to electric from manual to my 600 CFM but don't want to overwhelm it with too much pressure. Can you tell me what kind AZ sells and the cost?
Thanks! SQZBOX
ps; DAM TECHINSPECTOR IS GOOD, AIN'T HE? Sometimes I think he has a crystal ball or something.
  #17 (permalink)
Old 03-27-2010, 08:00 PM
Fuel Pump
Yeah this guy can nail it right on the spot no questions asked!! Thanks Mr. TECH! The pump at autozone costs $39.99. Brand is by Mr. Gasket. Small in size and not bulky. It even has it's own little gas filter with it but I still adapted my own filter.
Thanks,
JD
  #18 (permalink)
Old 09-19-2011, 09:55 PM
Originally Posted by 355Nova
I figured it out by taking air cleaner off first and looking into carb when someone shut off the car for me. The carb was just literally dropping the a little bit of gas for about 15sec after car was turned off.
I hinted carb when I had pulled out a spark plug and smelled gas on them. Reason I pulled spark plug was because I had no start. I also noticed that If I kept cranking engine it would start in long run but hesitated when I accelerated.
I bought a fuel pressure regulator at autozone and walla! I also took time to tune carb while I was at it.
I know this thread is old but i have the same problem. Only thing is i have a mechanical fuel pump. Is that what you have as well. I didnt think one would need a fuel pressure regulator with a mechanical fuel pump.
  #19 (permalink)
Old 09-20-2011, 12:10 AM
techinspector1's Avatar
Wiki Edits: 326
Temporarily mount a 0-15 mechanical fuel pressure gauge on the grille-work of the cowl, directly in front of the windshield and monitor the pressure through the glass as you drive. Use copper tubing for a temporary, cheap install to plumb between the gauge and the carburetor inlet point.
  #20 (permalink)
Old 09-20-2011, 11:04 PM
Ill have to try that. Just wanted to say that this is just a aftermarket fuel pump. No performance brand or what have you. Also the engine is from a 76 Chevy 3/4 ton Pu. I installed it in my 83 Chevy Pu 1/2 ton. I wasn't to sure what to set the timing to. When i called for specs. I was told a 76 Pu engine was something like 8 degrees btdc then i was told a 83 was set at 10 or 12 degrees btdc. Depending if it was a California model. I'm from Texas so i set it at around 9 Degrees if that makes sense. Not sure if this is my problem. I read somewhere that the mechanical fuel pumps have a spring by the arm and that when it goes bad it will shoot up the fuel pressure.Also i purchased this truck form a guy that had it parked for 2 yrs. Already resealed the whole engine. It is basically a stock 350 engine with a rv cam and a quadrajet. Thank you all for your time.
  #21 (permalink)
Old 09-23-2011, 07:42 PM
I attached a fuel pressure gauge.When i start the engine. The gauge just bounces back and fourth.Looks like from 5 to 10. Would someone please help. Thanks.
  #22 (permalink)
Old 09-23-2011, 09:26 PM
sqzbox's Avatar
You need to monitor the gauge while driving.
  #23 (permalink)
Old 09-23-2011, 09:31 PM
shouldn't i still have a steady pressure of around 5-7 psi at idle.
  #24 (permalink)
Old 09-23-2011, 09:35 PM
sqzbox's Avatar
At idle it shows your pressure regulator is working. Really need to take it for a ride and monitor pressure at cruise and WOT. I'm guessing you have a 2 line fuel pump?
  #25 (permalink)
Old 09-23-2011, 09:42 PM
I don't have a regulator on it. Its a mechanical pump from the parts house.Didn't think i needed a regulator. Not hi performance. As for how many lines. I need to check it again tomorrow. Its 2 or 3. Its a 83 1/2 ton Pu.I didn't think these trucks came with regulators originally,correct. Thanks.
  #26 (permalink)
Old 09-23-2011, 09:49 PM
sqzbox's Avatar
Sorry I thought you had one on there. I needed to read back to the first post I guess. It didn't come with a reg, though. Get back with results tomorrow ok?
  #27 (permalink)
Old 09-23-2011, 09:54 PM
You mean results while driving and monitoring the gauge.Ill see if i can scrounge up fittings. Im still wondering why the gauge is bouncing so much. I dont think it should be doing that. Its brand new. Wondering if its the spring in the fuel pump by the rocker arm.
  #28 (permalink)
Old 09-23-2011, 10:14 PM
Here is an interesting read. Its sounds like the fluctuation is normal and to use a oil filled gauge for more accuracy.
Fuel Pressuer Guage Jumping Around
  #29 (permalink)
Old 09-28-2011, 10:55 PM
Ok.i purchased a oiled filled gauge. It reads 7 psi. A little confused. Some say 5-7 psi is good readings for a mechanical pump while others say 5 psi only.
  #30 (permalink)
Old 09-29-2011, 08:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Because of the design of a OEM-type mechanical pump, it will have a fluctuation on the gauge- this is considered normal. The psi you are seeing- while borderline high- is still within specs.
You said there was dripping fuel entering the engine. What you need to be aware of, is the Q-jet will exhibit "nozzle drip" if the idle isn't right. And the idle is tied to the timing. Also check to see if there's any dripping happening right after you shut the engine off.
So, to start with:
What is the initial timing?
What is the vacuum is at idle?
Have you checked for vacuum leaks?
Is the vacuum advance working and if so, is it connected to ported or manifold vacuum?
If the float level is off either because the adjustment is wrong or the float has soaked up fuel and has become heavy, this will cause a too-rich condition. If the idle vacuum is insufficient to fully seat the power piston, this can cause a too-rich condition.
Blower Motor - Timing - Spark Plugs: Need Clarification Please 41willys Engine 19 08-31-2008 10:01 AM
Edelbrock heads / spark plugs ? driveability Engine 8 03-13-2006 07:29 PM
Spark Plugs on a 1999 grand prix rbfpezcore Engine 9 11-30-2005 09:37 AM
what spark plugs are best? 72 chevy elcamino Engine 4 07-12-2005 08:59 PM
Melting Spark Plugs Waterhead Engine 19 12-07-2002 12:09 AM
