Ok.i purchased a oiled filled gauge. It reads 7 psi. A little confused. Some say 5-7 psi is good readings for a mechanical pump while others say 5 psi only.
Because of the design of a OEM-type mechanical pump, it will have a fluctuation on the gauge- this is considered normal. The psi you are seeing- while borderline high- is still within specs.
You said there was dripping fuel entering the engine. What you need to be aware of, is the Q-jet will exhibit "nozzle drip" if the idle isn't right. And the idle is tied to the timing. Also check to see if there's any dripping happening right after you shut the engine off. So, to start with: • What is the initial timing? • What is the vacuum is at idle? • Have you checked for vacuum leaks? • Is the vacuum advance working and if so, is it connected to ported or manifold vacuum? If the float level is off either because the adjustment is wrong or the float has soaked up fuel and has become heavy, this will cause a too-rich condition. If the idle vacuum is insufficient to fully seat the power piston, this can cause a too-rich condition. |
• What is the vacuum is at idle? Havent checked it. Since the engine fouls the plugs . Figured i would have a bad reading. Due to the slight miss. • Have you checked for vacuum leaks?Yes,but ill check it again. • Is the vacuum advance working and if so, is it connected to ported or manifold vacuum?Yes its working,ported vacuum.Above the throttle plates. It has a metal float. Already checked it. It has not fuel in it when i shake it. As for the vacuum. Can i check it with that miss. Or will it give me a bad reading.Ill try to clean the plugs and get it as steady as possible to get a good reading. Their is no nozzle drip at idle.Let me see if there is any after i shut it off. |
I'm a bit confused. You responded to this post: Quote:
"I know this thread is old but i have the same problem. Only thing is i have a mechanical fuel pump. Is that what you have as well. I didnt think one would need a fuel pressure regulator with a mechanical fuel pump." What is the same problem you have? If it's not the carb dripping fuel, it must be the wet plugs? There are a ton of things that can cause the plugs to foul w/fuel- carb, anything on the primary or secondary side of the ignition, fuel pressure to name a few. Besides the fuel pressure, you need to rule out the ignition and carb float level, or blocked air bleeds, stuck power valve, internal leaks from warpage, bad well plugs, etc. |
More pressure will not make more horsepower. It will over-ride the needle and seat and blow raw fuel into the intake manifold, creating a tuning nightmare. Find a way to drop the pressure to 5 psi at the carb inlet and you will be rewarded with a system that functions properly. If I had a mechanical fuel pump and it was delivering 7 psi, I would either replace it with a pump that delivers the proper pressure or I would rig up a bleed back to the tank, with an adjustable screw to limit or allow more fuel to be returned to the tank. The Carter muscle car mechanical pumps spec a little higher than 5, but seem to work well on a street application.... http://www.summitracing.com/parts/CRT-M6624/ |
@cobalt327 What i meant to say in the quote was that My SPARK PLUGS keep fouling out out on me. It doesnt drip fuel while at idle. Ill have to check if it does after i shut if off. Also just curious How would one check the primary and secondary igniton. P.s. Tried to multi quote but i didnt have the multiquote option unless i missed it. All i saw was the quote button. |
Just out of curiosity the truck was sitting for 2 yrs. Wonder if trash in gas tank would have anything to do with it. |
Crap in the gas 'could be causing the needle & seat to leak intermitently , check a manual for the correct fuel pressure , Many GM products spec 5-7 as correct, also Q-jets are notorious for having 2 lead plugs in the bottom of the float bowl , accessable by removing the base plate, that leak . Their used to be a rubber plug that came in the carb kits to remedy this, but J_B weld works too.
dave |
| Blower Motor - Timing - Spark Plugs: Need Clarification Please | 41willys | Engine | 22 | 08-31-2008 10:01 AM |
| Edelbrock heads / spark plugs ? | driveability | Engine | 8 | 03-13-2006 07:29 PM |
| Spark Plugs on a 1999 grand prix | rbfpezcore | Engine | 9 | 11-30-2005 09:37 AM |
| what spark plugs are best? | 72 chevy elcamino | Engine | 4 | 07-12-2005 08:59 PM |
| Melting Spark Plugs | Waterhead | Engine | 19 | 12-07-2002 12:09 AM |
