My SPARK PLUGS keep burning out on me after a quick drive. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2010, 08:44 PM
I have a 1970 Nova. It has a 355 sbc with factory HEI setup. I have LT1 heads (Aluminum), 10.2:1 pistons, 1.6 rockers, shorty headers, ZZ4 cam,
holley contender intake, 750 double pumper.nks
I had a set of NGK type r spark plugs and they burned up, and engine would not start.
I replaced the spark plugs agian with a set of AC Delco plugs for a 1993 camaro, and it started on a dime but after going around block once, they did not work again like the first couple of start ups. I can start car but only if I crank it for a long time.
what kind of plugs do I get? Can the spark plug wires cause this?
Thanks,
JD
Old 03-23-2010, 08:53 PM
Last journal entry: New photos
Are they black when you pull the plugs? Do they smell like gas? They may be fouling because you are running too rich.
Old 03-23-2010, 08:57 PM
ericnova72's Avatar
More for Less Racer
Describe "burned up" - ground strap burned away??, center electrode burned away??, porcelain melted?? What color are the plugs??
What are your current ignition timing #'s??
What kind of plug wires are you using??
Old 03-23-2010, 09:03 PM
Spark plugs burning
Yes sure they smell like loads of gasoline and are black. Can I clean them? Or should I get a new pair?
Old 03-23-2010, 09:09 PM
You can clean them with a wire brush. Get most of the black carbon off and then use 220 grit sandpaper to clean the area where the spark happens. Finish by blowing the loose material away with compressed air.
Are all of your plugs black or just a couple? If they are all black then you are probably running too rich and need adjustments to your carb. If only a couple are black it may be other problems.
Timing numbers
The timing on my cam and crank are set to zero and the Distributor i'm not sure. It starts on a dime though when I got good plugs lol.
Thanks
jd
Old 03-23-2010, 09:16 PM
All plugs are wet fouled
Yes all of the spark plugs are black with gas. Since you mentioned to rich,
I'm almost certain it could be the Carb. It's a double pumper. I had one before on a trans am and it bogged the crap out of it. Can I run a higher voltage coil to solve problem? The car doesn't blow smoke or bog down.
Thanks,
JD
Old 03-23-2010, 11:34 PM
sqzbox's Avatar
My pipes are my music
plugs
What heat range plugs are you using? Instead of buying plugs for a 93, try A/C's for a 70 LT-1 370 hp camaro. Might be closer to what you need.
Old 03-24-2010, 01:58 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Geez, get the fuel pressure under control. No modern 4-bbl carburetor needs more than 5 psi fuel pressure. More pressure than that will blow fuel past the needle and seat right into the intake manifold.
Old 03-24-2010, 06:26 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
If your plugs are gas fouling, it doesn't matter which plugs you use, if even if your ignition is nuclear fission powered, it's still gonna foul them. Like Techinspector said, gotta get your carb and fuel pressure sorted out. I seriously doubt your timing is helping either. With that cam, you probably gonna want about 12° to 14° of initial timing. I'd definitely do that next, then bead blast or replace your plugs, and see what's up with the carb/fuel pressure.
Old 03-24-2010, 11:20 AM
F-BIRD'88's Avatar
Yada Yada Yada
1970 cars had a points ignition. If running a HEI you must ensure the thing is getting a full 12 volt power. if not replace the resistance wire between the distributor and fire wall joint.
Check the cylinder head casting number. LT-1 aluminum heads are GEN II design and are not compatable with a gen 1 block. (water passages) Which heads do you really have? casting number under valve cover.
get a timing light The carb's power valve diagram may be pouched. That will make it run real rich and foul the plugs. 750cfm DP carb use a 70pri 80sec jet and 6.5" power valve.
Old 03-25-2010, 12:41 AM
sqzbox's Avatar
At this point, I would get it started and be looking down the carb and see if fuel is driping from the boosters (float level high) if not, I would check the power valve or check ball missing from the accelerator pumps.
I can give you an old troublshooting card from holley to give you some ideas
to check out. You'll have to enlarge it a bit~! Hope it helps.
Name:	trouble shooting chart.jpg
Old 03-25-2010, 10:21 PM
Fixed the spark plug problem
It was the fuel pressure. There was so much pressure that the gas was leaking into the intake after the car was off. Plugs were fine after about 2hrs of sitting. Car started right up fine after I fixed the pressure problem.
Also about the heads GenII on GENI, it can be done. The setup that I have is a 4-bolt 350 out of a 77 chevy truck, converted to a newer roller style sbc. I welded certain water ports closed and redrilled them to the proper size for the GENI gasket style. If you do not do this, then water will drop directly into the lifter alley. I have 1.6 rockers for the LT1 heads and higher poundage springs. The heads are ported all the way. and gasket matched. Gasket is regular felpro standard size. I have a holley contender intake, and 10:1 Hyp-pistons. I got very good results! I got great torque! I punched the gas last week on Tuesday and CRACKED my tranny housing LOL.
If you guys are interested I can give you more details on the build.
Also for the 1985 Chevy 350, Honing is a very fast procedure and is very very easy, and not to mention ALOT CHEAPER then machine shop.
Details on my build:
Heads $40 from craigslist
Porting did myself
Intake $30 craigslist
Rockers new $60 craigslist
Valve covers $10 junk yard
Pistons and piston rings new and gasket kit for 350 sbc $156.23 ebay
Carburetur $100 from craigslist
Honing tool and piston compressor tool ~ $23
Cam ZZ4 $50 craigslist
Roller lifters and push rods about $65 ebay
Total around $550 machine shop over $2.2K - $3k because of custom welding and misc bull! LMAO!
Old 03-25-2010, 10:47 PM
F-BIRD'88's Avatar
Yada Yada Yada
Let me guess..... solid motor mounts...
Old 03-25-2010, 11:32 PM
No solids
I think the tranny just had it coming lol! It cracked near the tail. I think car was a dust collector until I got a hold of it. Probably sized up while I punched it and cracked not sure. I got a new tranny b&m specs and can burn tire with gas not pressed down far at all. I did a dyno last week and Torque was 463.
I have v belts, alternator, pwr stering, ac pump, fan clutch. I plan to gain at least 15hp more taking all this to electric.
Blower Motor - Timing - Spark Plugs: Need Clarification Please 41willys Engine 22 08-31-2008 10:01 AM
Edelbrock heads / spark plugs ? driveability Engine 8 03-13-2006 07:29 PM
Spark Plugs on a 1999 grand prix rbfpezcore Engine 9 11-30-2005 09:37 AM
what spark plugs are best? 72 chevy elcamino Engine 4 07-12-2005 08:59 PM
Melting Spark Plugs Waterhead Engine 19 12-07-2002 12:09 AM
