My Speedometer reads too fast - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2003, 08:55 AM
Post My Speedometer reads too fast
I have a cable driven non-adjustable speedometer connected to a TH-350 trans and my speedometer is always 7mph faster than actual speed. I presently have an 18 tooth gear in the trans. Should I go to a 19 tooth or 17 tooth gear to adjust the reading? Someone once told me one tooth adjustment will deliver about a 5 mph correction. Thanks for the Advice!
Old 03-25-2003, 09:25 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I fix these problems by going down to my local speedometer shop and having them put in an auxiliary gear box that precisely corrects the difference. Cost is something less than $100 and you end up with a laminated spedometer calibration certificate. The gear box simply screws in between the cable and the tranny using the standard large swivel nuts. Check your phone book. Most medium sized cities have spedo shops. The cheapest alternative is just drive 5mph faster all the time!
Old 03-25-2003, 11:54 AM
Deuce UK's Avatar
New Member
Post
jpd37, take a look at this site.Speedo Gear Selection
changing the gear is easy....if you dont know that already. that calibration box sounds cool. I dont think we could get them in the UK. Getting the gear for my TH350 was hard enough.
Old 03-25-2003, 03:31 PM
bullheimer's Avatar
NEVER use credit cards!
Post
if you got that box hanging off the tranny it's like $29 at GM. speedo shop will tell you what to do. by the way, howz things in BH? i went to BHHS 69-71
[ March 25, 2003: Message edited by: bullheimer ]</p>
Old 03-25-2003, 04:40 PM
airworld2's Avatar
Post
how can you have a non adjustable speed o are you dealing with a chevy 350 trans or buick olds or pont? they make different outside gears for all the above. the rule I've learned 1 tooth on driven gear is about 3 miles an hour. use known car or truck with accurate speedo to check after you replace outside gear they cost about 5-10 bucks from your local gm dealer.add teeth to driven gear(outside gear) to slow down subtract teeth to read faster.
[ March 25, 2003: Message edited by: airworld2 ]</p>
airworld2
Old 03-25-2003, 04:46 PM
Post
I like this calculator it makes it so much easier.
Old 03-25-2003, 04:57 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Post
Here is a link to a search for "speedometer calibration" in the Hotrodders Knowledge Base. Hope that helps .
Old 04-02-2003, 09:37 AM
Post
Thanks Jon for the tip on the hotrodder's knowledge base. I have not learned how to use this site altogether yet, so the link really helped. I bought a new speedometer driven gear after doing the calculations and the fix is less than 1 mph off. Fantastic! The total cost of the fix was $3.35. Hard to beat and I don't have another gizmo to fail on me. Thanks to all with tips, ideas and advice. This continues to be the best site for information!
