is my stall performance normal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2010, 10:18 PM
45woody
hey,have 3400 stall on th400 trans,powered by 461 bbc,309 dur-540 lift,and so on,is it norm,from sitting still to any type of forward movement,right around 1800-2200 rpm?like trying to drive standard trans with clutch half way in.or is this another prob? 3:42 posi rear.
Old 10-31-2010, 01:09 AM
ericnova72's Avatar
More for Less Racer
It's normal. A higher than stock stall like yours will feel "loose" at a mild rpm like that below its stall point, just takes a little getting used to. The feeling is more noticable on 3200 rpm and up stall converters.
Old 10-31-2010, 07:33 AM
Onefunponcho's Avatar
Your stall sounds normal... one other thing that to keep in mind....as big a stall as you have and with your rear gear you may be getting some slipping still from your converter while at cruising speed. Make sure you have a great big tranny cooler. I burnt one up before because of that oversight.
Old 10-31-2010, 08:16 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 it's normal.
Cole
Old 10-31-2010, 03:03 PM
45woody
3400 stall....
hey,thanx for response,whew!this project has been quite the ordeal,have 4 qt derale pan w/cool tubes,waiting for guage and trans cooler w/fan,only have 26000 gvw tranny cooler right now but no temp guage.so have no idea how hot im gettin around town.
SBC stroker project, small budget jankinnu Engine 82 11-21-2010 10:53 PM
700 r4 stall converter? 27 or 30 spline? brownk2010 Transmission - Rearend 2 06-12-2010 12:05 PM
Stealth marketing bust: Race Ready Performance Jon Hotrodders' Lounge 0 03-20-2008 02:05 PM
Stall Coverter mightycarlo10 Transmission - Rearend 2 01-02-2008 07:14 PM
Auto Performance Business Venture Plan Opinions(long read) TurboS10 Hotrodders' Lounge 17 12-01-2003 09:33 PM
