My storage idea for heat lamps, maybe something you could use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2013, 11:13 PM
I simply pull the lights off their stands. Slide them over this rack I made that is bolted to the wall and the stands are stored outside.
Old 03-18-2013, 08:06 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Simple and cool. Now I have ANOTHER project !!
454 RATTLER
Old 03-18-2013, 10:33 AM
Faith - Respect - Trust
Good idea Brian. I have 2 of the same lamps that you have, I don't use them as much as I used to but they can take up a lot of space with their 4 pronged base plate. What I did was take a tire and rim with the tire still inflated on the rim complete with brake drum axle and wheel bearing still attached. Then I opened up the rectangular tubing that holds the heat lamp and slid it over the axle. Now when I need to move the lamp I simply grab the top of the stand, pull the whole unit to a 45 degree angle and wheel it to where I want it. The weight of the tire rim and brake drum hold the lamp in place while I'm curing whatever material needs to be cured and moving it out of the way is much easier. The tire and rim take up less room than the original base and now when I'm walking by I have less chance of tripping over it. It doesn't save as much space as what you did, I like the idea of having the lamps up and out of the way, I still manage to bang into those lamp heads...my next new thing to do for the organize the shop projects.
Thanks Brian
Ray
Here's an idea for power tool storage. evintho Garage - Tools 7 11-03-2012 02:35 AM
heat lamps ok for painting heat source? matt167 Body - Exterior 4 11-12-2008 04:55 AM
curing lamps coupe33 Body - Exterior 6 01-01-2008 06:03 PM
Fog Lamps.. Theresa Shank Electrical 3 06-18-2007 08:27 PM
Help! Tail Lamps, but No Turn Signals or Brake Lamps 41willys Electrical 12 01-02-2006 08:11 AM
