figured i start a thread to document my th350 build for my turbo car
hopefully ill have better luck with this trans then the professionally built th400 i had before this
what i started with was a 9inch tailshaft th350c , and a 6 inch tailshaft th350
well in my app i need the 9 inch tailshaft so i tore down the th350c to steal the tailshaft housing and output shaft from it.
ill also being using some other misc parts out of it as they should be in better condition then some of the th350 stuff
heres the th350c i tore down
and here is the rebuild kit i bought for 100$'s
shortly after i bought all that a huges reverse manual/tranbrake vb came up for sale on tgo along with some other goodies
so for 400$'s i ende dup getting the huges manual/tbrake vbody , a jw lightewiegth ultrabell + the already modified trans case
which was a really good price btw
and finally my 8" fti 3,800-4k stall converer
the plan is to finish tearing down the other th350 i have for the input shaft/pump and other parts i need between the th350 and the c , and then get everythign cleaned and ready to go for assembly on monday
when i start to assemble it on monday ill be sure to take plenty of pics of the progress
one thing i prolly should have bought and didnt which mite bite me in the butt later down the road is some aftermarket input and output shafts, but only time will tell on that
btw if anyoen can recommend a good trans cooler for this thing it would be greatly appreciated, ive never used a tbrake before on any of my own cars before so not sure how much larger my cooler needs to be then normal , id prefer a cooler that comes with an fittings on it as i plan on using pushloc lines for the connections versus hardlines
