Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My T-400 Tranmission Will not go into any gear.
Old 10-24-2012, 07:23 PM
idontdrivericeieatit idontdrivericeieatit is offline
Pull a transmission line and start engine put into gear and see if it sprays fluid out if it if it dont then its front pump if it does could be torque converter is bad but I would start with front pump as u dont have to pull it to check it and u sure has plenty of fluid mine dry took 12 quarts with the transmission cooler
