My T-400 Tranmission Will not go into any gear. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2012, 04:30 PM
I recently dropped a SBC (350) into my 1980 camaro, the transmission had been sitting out of the car for about 8 months, But when i drove it last, it shifted fine, so why it would stop working out of the blue is beyond me.
I did remove the oil pan and change the gasket/filter, but I thought I was very careful not to touch anything else.
The car is on jack stands
The only thing that works is park. At first I thought it was the shift linkage But then when i ran the engine, and moved the lever on the trans manually into the gears, NOTHING happens.
Reverse or 1st,2nd,3rd. Nothing
Driveshaft is seated correctly
the fly wheel spins, the torque converter spins.
When I installed the torque converter I was very careful to make sure I got the "Two clunks" so to know it was seated properly
The vacuum line from the (edelbrock) carb to the modulator is set up correctly, and there is plenty of FRESH automatic fluid in trans as well.
There is an electrical plug on the driver side But i dont ever recall it being set up even when it was driving?
Is there something Inside the transmissions Im suppose to connect?
This is making me crazy, Ive been working on this car forever Im so close to driving this car and the amount of frustration is becoming unbearable.
There are very few people I could ask for assistance.
Please lend some knowledge, Im 21 and have much to learn.
Old 10-21-2012, 05:03 PM
RWENUTS's Avatar
Did you put enough tranny fluid back in?
Flywheel spins! Torque convertor spins! Seperately or togethor?
Old 10-21-2012, 05:25 PM
No they spin as one unit, Torq Conver is bolted to the flywheel
there is plenty of fluid in transmission
Old 10-21-2012, 05:48 PM
RWENUTS's Avatar
DRain it time!
Check the filter again.
Old 10-24-2012, 08:23 PM
Pull a transmission line and start engine put into gear and see if it sprays fluid out if it if it dont then its front pump if it does could be torque converter is bad but I would start with front pump as u dont have to pull it to check it and u sure has plenty of fluid mine dry took 12 quarts with the transmission cooler
Old 10-24-2012, 08:28 PM
And I have never seen a torque converter spin without the flexplate or flywheel bolted to it. if its doing it separate thats a new one for me and would love to know how thats possible
Old 10-24-2012, 08:49 PM
Dennis W. Parks
I would say to check and recheck the tranny fluid level. Basically, the tranny works based on fluid pressure, so if the fluid is low, you ain't gonna go.
Dennis W. Parks
author of automotive how-to books
Old 10-24-2012, 09:49 PM
Well I feel retarded
Thanks guys so helpful!
I checked the fluid levels again, but i didnt account for the fluid in the intercooler + fluid in the torque converter not to mention I have an After market B&M (deep) pan. SO there was my problem of why it wasnt moving/ going into gear.
So After adding more fluid, shes driving. And i was VERY excited! haha
But now it feels like there is a big power loss, like im having to rev too much to go a certain speed. fastest ive gone is about 20 mph.
I have a Bored .40 over 350, she should be puttin out 400+ Hp
Didnt get on it, because the last time i gave it a hard throttle The Vbelt FLEW off! It wasnt a big deal since the car was in Neutral and i was setting up the throttle link cable, but i wouldnt want that to happen while im driving!
350, gears, sbc, th400, transmission
turbo 400 only has 5 gear positons 85 k5 mud truck Transmission - Rearend 6 05-31-2009 10:17 PM
tranmission swap m2summit Transmission - Rearend 3 03-07-2008 07:03 PM
400 searching for gear price Transmission - Rearend 1 07-18-2007 12:17 PM
T-400 governor gear breaks off 63droptopnova Transmission - Rearend 7 05-30-2007 07:10 PM
TH 400 low gear conversion JPhil Transmission - Rearend 17 09-06-2006 06:08 PM
