my t.b.I. 4.3l v6 puts out way to much fuel at start then revs way up on it's own - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2011, 04:59 PM
I just put a t.b.I. 4.3 out of a 89 s10/blazer into my 88 s10 pickup that had a stock 2.8l v6 and I finaly got everything swapped and started it up but everytime the injecters throw out too much fuel where it's splattering out of the throttle body all over the engine then after I let it sit and run like that it revs way up with out me touchen the throttle at all and if I do hit the throttle it chokes it self out and revs down until I let off then it revs way up again... Any ideas or solutions?
Old 07-11-2011, 06:39 PM
LATECH's Avatar
check the fuel pressure, should be around 13.
Also you need to put the ecm from the 4.3 in it.
any check engine light?
Is the MAP sensor hose hooked up to the correct port?
Old 07-11-2011, 08:36 PM
DoubleVision's Avatar
As mentioned, check the fuel pressure. What codes is the computer giving?
Also could be IAC is bad.
Old 07-11-2011, 10:30 PM
What would it mean if my fuel pressure is too high?
Old 07-12-2011, 01:39 AM
FastOrange's Avatar
Check the Coolant Temp Sensor. when they go bad, they can tell pcm its -40 outside.
Old 07-12-2011, 06:10 PM
LATECH's Avatar
That means the return line is restricted or blocked. That will send the fuel pressure real high, and could give the trouble you are having.
Check to see if it is pinched or kinked somewhere and unkink it.
Old 07-12-2011, 07:08 PM
LATECH's Avatar
the FP regulator could be bad too. It is built into the Throttle body
Old 07-12-2011, 08:17 PM
sbchevfreak's Avatar
Licenced Automotive Technician
x2. Very common on the older TBI units.
Old 07-15-2011, 05:53 PM
It still does the same thing, put new fp regulator, iac valve, and o2 sensor
Old 07-15-2011, 06:50 PM
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
It could be the throttle position sensor (tps) or even the coolant temp sensor (cts) i would start with the tps over the cts. I know on the 944s the coolant temp sensors would go bad and cause it to do the exact same thing back in the day.
Old 07-15-2011, 11:07 PM
Ya I thought of that too and I put the cts from the 2.8 on the 4.3 dint do anything with the tps yet cuz the way it sounds while it is running it sounds like it is taking in alotta air but I will still try the tps, but shoudnt the service engine light be on if any of those sensors are the problem?
Old 07-15-2011, 11:09 PM
I just don't get what could of happened cuz I had it running fine in the blazer before I put it in my s10
Old 07-16-2011, 02:09 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Did you check the fuel pressure yet?
Old 07-16-2011, 03:11 AM
New Member
Old 07-20-2011, 09:45 PM
Any other suggestions on why my engine would run like that? And now when I turn the motor over the negative battery cable sparks and smokes at the battery terminal and I think the ground strap on the back of the head did the same thing!!! I checked the ignition wire at the starter and it seemed fine, what happened with that??
post music that puts you in a good mood tech69 Off-Topic 46 05-18-2011 09:03 AM
Chevy Truck Guy Finally Puts Up Pic's OMG! ChevyTruckGuy Off-Topic 36 03-21-2007 03:54 PM
Revs? stroker_SS Engine 11 03-18-2006 02:45 AM
Foose still puts bondo on bare metal Slickriffs Body - Exterior 10 02-03-2006 08:05 AM
who puts alternators in generator bodies? goodusedparts Electrical 4 11-08-2005 09:35 AM
