Is my timing tab off? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2011, 03:14 PM
SUX 2BU's Avatar
My truck runs alright but it can run better. I bought a timing light to see where my timing is at. I put an MSD timing tape on, and made sure it was on correctly, put white out in the groove in my 6.75" balancer and marked the 15 and 38 degree marks because the timing tab I have goes right to the edge of my balancer. I dont' understand that because it then makes it very difficult to read the timing tape!
Anyway, upon using my timing light I find that at the 0 degree mark on the timing tab it shows up at my 38 degree mark on the balancer! That doesn't make any sense so I'm wondering if I have the wrong tab. It's the same I bought the truck with 7 years ago (350 was redone in 1999). Had the cam and heads redone in 2008 and my mechanic mentioned some trouble with the timing but said he got it figured out. I'm wondering what he meant by that now. My truck runs okay but I think there is more power in it. It surges a little at low-RPM cruise, doesn't ping at all even on 87 octane but nose dives some at more than 1/2 throttle then recovers. It's run a best of 14.87.
This is the tab I have:
That's not my motor but it's same tab (the bright, large one)
Motor specs:
60-over 350, Dart Iron Eagle S/S heads (165cc, 1.94/1.50), headers, Eddy 650 carb, alum. dual plane intake, Mallory Unilite HEI, flat-tops, Weiand water pump, stock (as far as I can tell) balancer. The previous heads that were on it were from 1972 so I'm guessing that's the block's date as well.
I know GM used different timing tabs but at what orientation? 12:00, 2:00 and ?
Old 06-14-2011, 03:45 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.crankshaftcoalition.com/w...op_dead_center
Old 06-14-2011, 08:10 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Here's the difference:
Is it off by that much?
Old 06-15-2011, 12:34 PM
SUX 2BU's Avatar
It does look off by that much! I was thinking I'll check it again with my light and see if the balancer groove is about at the 12:00 position. So either that or my balancer slipped a whole bunch, eh?
Thanks for that link about finding TDC, tech. That procedure would take me an awful long time as I only get an hour or two to work on my truck here and there, so that would be quite a process. Plus having to use a buddy to help out too, as I normally work alone whenever I find the time.
Old 06-15-2011, 01:57 PM
Wiki Edits: 326
SUCKS 2 B U dude.
Old 06-15-2011, 02:26 PM
Greg T's Avatar
www.krusinklassics.net
A piston stop takes about 10 minutes to use and will give you a definitive answer to your quandary. Why would you not just beg, borrow or steal one and use it?
Old 06-15-2011, 03:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Just make one out of an old spark plug...took me about 5 minutes.
Semper Fi
Old 06-20-2011, 06:58 PM
SUX 2BU's Avatar
For the $8 they cost, I might as well buy one.
I checked my timing again and the balancer groove is pretty much right at the 12:00 mark. Maybe slightly right of it, so I wonder if I have a balancer that is meant for the 12:00 timing pointer.
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 09:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 08:54 AM
Base Timing - Advance timing chevelle67 Engine 3 05-11-2004 08:45 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 02:35 AM
Timing help? Timing bounces and drops?!?! fireforsin Engine 1 09-12-2003 01:32 AM
