Is my torrington roller thrust bearing needed on my timing chain? SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2009, 05:20 PM
Hi guys I am in the process of tearing down my 350 sbc for a cam swap and I should have it all open to swap out cams by Thursday. I installed a jegs billet steel timing chain set last summer and it came with a torrington roller bearing on the back of the cam sprocket. The block has been clearanced for double roller chain anyways and was wondering do I really need to use it? I don't really want to get a new timing chain since mine should still be good since I have only about a few hundres miles on it.
I would like to take it out so I don't have to worry about it failing on me and then end up with roller bearings throught out my engine. Has anyone ran a similar timing chain like this and went with out it with no problems? Is it really necessary to run one.
Thanks guys.
Eric
Old 07-21-2009, 05:34 PM
Thanks guys.
Eric
I share your worries over roller thrust bearings coming apart. My personal choice would be to use a simple washer style thrust bearing. Keep in mind that the chain needs to be aligned thru the gears. This means that cam gear is usually clearanced for a thrust bearing when one is supplied. The OEM gear runs against the block without benefit of a thrust bearing. This is mostly OK to run the aluminum gear hub against the cast iron block, but it does mean that the block face is subject to possible wear and this is an item not easily repaired, so a thrust washer is a good idea to protect the block.
Bogie
Old 07-21-2009, 05:41 PM
ericnova72's Avatar
More for Less Racer
You can't run what you have without the bearing because the back of the gear has been machined away to allow room for the bearing assembly. The only way to eliminate the bearing is to make a brass thrust washer the same thickness as the torrington assembly.
Old 07-21-2009, 06:04 PM
Well that sucks I was hoping to not have to have it on there. I ordered a bronze thrust bearing from summit but it would not fit it so I don't really want to buy a new 70 plus dollar timing chain right now. My hours at work have been cut so I have lost some income and just have enough to get gaskets etc to seal everything back up. O well I will see. Thanks for info
Eric
Old 07-21-2009, 09:20 PM
406 bug's Avatar
9.82 @ 139mph
measure your thrust bearing that came with the timing set and contact some of the aftermarket timing set manufactures, most offer both thorrington and solid thrust/wear plates. I am sure someone will have a match.
Old 03-06-2015, 04:02 PM
you might try looking here (www.skf.com/group/products/bearings-units-housings/roller-bearings/index.html).
these are the best I've found, the costs are low and there are all sizes.
or these (www.omniabearings.com/bearings/roller_bearings/thrust_roller_bearings), are Germans, have average costs but high quality.
you should be able to solve the problem.
good luck.
Old 03-06-2015, 04:22 PM
Thanks for answering ha ha but this is an old thread. I was able to get a different timing set and it has the solid bronze thrust bearing and all was put back together and is still running good
Old 03-06-2015, 04:48 PM
lol sorry!
timing chain or distributor? k2c1959 Engine 3 07-21-2007 03:10 PM
Correct Timing Chain Tension mouseman Engine 7 09-20-2005 08:43 AM
350 double roller timing chain help..... SideSlip Engine 3 09-12-2005 10:56 PM
overheating after installing timing chain 85 vette Engine 11 01-04-2005 09:12 PM
timing chain? 85 vette Engine 9 12-05-2004 06:56 PM
