my tran is vibrating when it changes gears !! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2002, 02:34 PM
Post my tran is vibrating when it changes gears !!
My tranny is vibrating when i change gears after 1st, except when i have teh excelerator down, i just put in an engine and i am having problems with the tranny... the reason i put the engine in there is because it is a 1974 camaro that came with a 250 straight six (which i am now selling)
and i put a 305 HO in there. the flywheel had broken off....
Old 07-06-2002, 06:21 PM
Tom Tom is offline
Post
try a new torque converter you may have some vanes broken in it especially if you broke a flywheel
Old 07-23-2002, 10:14 PM
Thumbs up
Im confused flywheel is manual trans flex plate auto if its manual and you did bust flywheel extensive internal damage expected.If automatic trans, torque converter or internals.Youll get it ,good luck!!!
