My tranny will not lock into Reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2009, 11:47 AM
I have a Turbo 400 fresh install, checked linkage from tranny to shifter, TCI tranny BnM shifter, could I have forgotten something swapping out the Turbo 350. vacuum line to carb, checked,lines to cooler, checked, is there something else? It pulses back on an incline, like jumping teeth or popping as it rolls.
th350 has only reverse Merickk Transmission - Rearend 1 01-04-2005 02:07 AM
Tranny update/Torque converter question RObs71Nova Transmission - Rearend 5 12-16-2004 09:37 AM
No reverse after Overhaul SG2nite Transmission - Rearend 9 10-31-2004 03:52 PM
th350 reverse double apply??? eskoskimo Transmission - Rearend 1 10-11-2004 05:07 AM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
