Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My truck will turn over but will not start any ideas?
Old 12-22-2012, 02:37 PM
1939P7 1939P7 is offline
thewrongshop@yahoo.com
Originally Posted by Hristamaki View Post
I checked the power going to the pump by unplugging the harness before the tank and it had 0 power the selector valve is what switches the two tanks I put a jumper wire there so I can only use one tank on my driver side. I also tested my fuel pump twice by hooking it up to power and it sot out gas just fine
run a wire from the relay to the pump and don't use the harness wire at all just bypass it ... if you get fire in the hole somewhere the frame or something rubbed a wire to the fuel pump....
