My truck will turn over but will not start any ideas?
I have recently had a problem with my truck it is a 1987 chevy r10 with the 305 Tbi for some reson I am not getting any power to my fuel pump I replaced the fuel pump relay, checked fuses, and checked my selector valve. Not sure what else would be some help would be great thanks!
Did you check the wires under by the fuel tank harness .. heres a link to steer you towards the testing. Hope it helps you..
Fuel Pump Problem-- NEED HELP!!! |
start first to see if the relay is being energized. If you still have the old relay take the cover off it and see if it energizes when you turn the key on. there are a lot of things that could be wrong. You need to start at the relay and work out from there.
Did you test the fuses with a meter? I have seen several blown that look fine.
Artificial Intelligence is no match for Natural Stupidity Chet |
My relay has power, so would that mean my problem is between my relay and my fuel pump?b but what is there besides wires and grounds?
I checked the power going to the pump by unplugging the harness before the tank and it had 0 power the selector valve is what switches the two tanks I put a jumper wire there so I can only use one tank on my driver side. I also tested my fuel pump twice by hooking it up to power and it sot out gas just fine
Now, are you testing the system correctly? There should be +12V at the relay feed, but you WON'T get anything to the pump unless either you just turned the key to START (that two second timer) OR you have oil pressure that closed the switch. The only way to test the pump and wiring is to remove the relay and temporarily jumper across the two pump contacts in the relay socket. If the pump turns on, the circuit is working. If not, use a test light to trace the wire from the relay connector to the tank. The selector switch is a likely candidate, as are all the connectors in the harness. If you now get 12V at the tank, check the pump and ground wire at each tank. |
Where would the reset button be located?
oil pressure
If memory serves GM did not use an inertia switch for crash shutoff of the fuel pump. They relied on the engine oil pressure to maintain the power to fuel pump. The idea is that, in a crash, if the engine is not running the fuel pump will also not run.
I believe Ford used an inertia switch. ![]() To test the system install a fuel pressure gauge on the injector manifold. Key on starts a 2 second prime run of the fuel pump. Engine cranking, oil pressure increases and runs the fuel pump. Engine running, oil pressure = fuel pressure. There is a gray wire to the fuel pump. If this wire is broken run a new one. vicrod |
| The Following User Says Thank You to vicrod For This Useful Post: | ||
cobalt327 (12-23-2012) | ||
Go to passenger side under hood remove large plastic cover marked fuel pump -fuel relay unplug relay install jumper wire across where you unpluged relay with ignition on you should hear pump run with gas cap removed or have assistant hold head close to cap,if it runs you found problem ,my 1988 chevy does have a low oil pressure cut off switch it has 2 sending units one under distributer one beside oil filter the other in front of filter is knock sensor ,i had to replace both on mine before pump would run ,if i turned mine long enough to build 18 lbs oil pressure aprox 60-90 seconds it would start hope this helps
You all really need to read the factory service manual and look at the factory wiring diagram.
1) There is no inertia switch on an 87 Chevy truck 2) There is only one oil pressure switch that controls the fuel pump. Again, this is used once the engine is running and there is oil pressure. 3) The relay is only used to prime the system prior to oil pressure rising. The relay is controlled by the computer and is only activated for about two seconds after turning the key to START. Yes, as I noted above, a good troubleshooting method is to remove the relay (which is on the firewall) and jumper across the pump terminals to get the pump to stay on. 4) The only other switch in the fuel pump circuit (other than the ignition switch) is the tank selector switch if the truck has dual tanks. That's it. This is a very simply circuit. By the way, if the relay (or computer activation of the relay) goes bad, it is often possible to start a TBI truck by cranking the engine long enough to build oil pressure. That will finally turn on the pump and operate the TBI. This can take quite a while. |
| Truck won't turn off.... | eyesore84 | Engine | 8 | 01-03-2012 06:36 PM |
| '85 VW won't start, any ideas? | primalfear6 | Engine | 5 | 04-27-2009 09:08 PM |
| help... will turn over but not start | downdeuce | Electrical | 2 | 04-29-2007 04:53 PM |
| 62 chevy truck turn signal | truck man | Electrical | 6 | 10-11-2006 05:04 AM |
| Tubbing My Truck, need some ideas. | F-1Rodder | Body - Exterior | 4 | 02-17-2002 04:30 PM |
