Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - my truck's dead at dead and sitting at the gas station
Old 09-05-2003, 09:39 PM
drlindz's Avatar
drlindz drlindz is offline
Since it started after you got it home, I would suspect the fuel pump relay. Had an Oldsmobile that had the same problem then mysteriously started the next day. Happened a few more times before I discovered the bad relay.
